By Stoney
#25028 bump !
added a wifi_station_set_auto_connect(0); to my sketch just to make doubly sure that no wifi was happening that I can think of..
still no dice, 64mA no matter what sleep option selected.
also updated to the latest arduino build..
any thoughts people ?
By willfly
#25112
Stoney wrote:bump !
Code: Select allESP.deepSleep(SLEEPTIME * SECONDS, WAKE_RF_DISABLED);
should be 15 mA constant. Are you sure your measurement is correct. Can you log on to your router and verify that ESP is indeed not connected.
By Lance Henderson
#25134 I have noticed this also. I had the code working on a previous build of the Arduino Package. I then updated the package (due to an NTP bug in the previous one) and I found that the micro would no longer wake into RF disabled mode.
I have been using the identical sketch code between the two.
