By Scottwday
#21482 I had the same problem, even with pullups etc, the serial adapter was driving GPIO0 the wrong way.
I made a little modification to the arduino serial monitor to allow me to set the DTR and RTS pins.
https://github.com/arduino/Arduino/pull/3386
Hopefully they will pull it.
Now I can hit upload on the arduino IDE and it uploads and starts running, no hardware required.
By brutzler
#21895 Hi @all
little feedback.
Made a little Dev-Board with the informations collected in the past.
- FTDI232 as USB-TTL-Converter, Jumper at 3,3V to have 3,3V-level for TXD and RXD
- a little breakoutboard, with a 5V -> 3,3V-Converter. Input supply from the 5V of the FTDI, Output to feed the ESP8266 (ESP-01)
- Reset and Flash with the schematic of the NodeMCU: http://www.esp8266.com/viewtopic.php?p=21209#p21209
- Reset, CH_PD, GPIO0 with a 10k Pullup to 3,3V
- The ESP8266 and FTDI is on header, to be changed quickly.
==> Result: Flashing and Serial Monitor (out of Arduino IDE 1.6.5), and normal Operation working without changing the wiring. Thats what I wanted to have.
so long... brutzler
