By jantje
#25289 @fonly82,
I do not like the argument -DARDUINO=165-r2 in your command line
First of all I know builds have failed in the past because of the -r2
Secondly the nightly should strip the -r2 and give you something like 10605 https://github.com/jantje/arduino-eclipse-plugin/issues/283
So my guess is you do not have the nightly.
@kolban
I am making an assumption that the ESP8266 arena isn't one you are that familiar with?
Your assumption is 100% correct.
By Dhruv Acharya
#56228 Hi,
I want to thank jantje and kolban for amazing work.
folny82 wrote:
Code: Select allsubdir.mk:24: recipe for target '.ino.cpp.o' failed
mingw32-make: *** [.ino.cpp.o]
I got this same error like "subdir.mk:26: recipe for target '.ino.cpp.o' failed". I tried something which temporarily solved my "thing".
Info:
  1. I downloaded sloeber V3 "win32.2016-08-02_04-26-49"
  2. I have installed Arduino 1.6.12
Steps:
  1. I made temporary copy of "tools" folder for future reference which was at:
    C:\Users\<YourUserName>\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\tools
  2. Copied the folder:
    C:\Users\<YourUserName>\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2
  3. Pasted at:
  4. Renamed it with "xtensa-lx106-elf"
  5. Copied the folder:
    C:\Users\<YourUserName>\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9
  6. Pasted it at:
  7. Renamed it with "esptool"
  8. The tools folder will look like this:
Now this solved my problem. But please suggest me if there is an easier way to solve it.
