Vicne wrote:Fixed
I added the following line to the init code:Code: Select allSPI1C2 |= 1 << SPIC2MISODM_S;
Nice catch !!!
Congrat !
Explore... Chat... Share...
Vicne wrote:Fixed
martinayotte wrote:Nice catch !!!![]()
Congrat !
Me-no-dev wrote:Good catch on that option! Honestly I never tested ESP <-> ESP over SPI and have always used AVR Arduino for testing. Probably that is the reason I never saw such error and ended up in your situation.
if(CPOL) {
SPI1P |= 1<<29;
} else {
SPI1P &= ~(1<<29);
//todo test whether it is correct to set CPOL like this.
SPI1C2 |= 1 << SPIC2MOSIDM_S;
The command bytes can be changed to something else through the registers, but the general protocol must stay the same. SPI1S3 is the register in question.
