By JerryESPN
#52729
schufti wrote:I still don't understand why you don't use deepsleep.
Lowest energy consumption, maximum life on LiIon cell....
Just fried my first ESP-01 while trying this. I don´t think, my equipment and "soldering skill" is yet good enough to realize that.
So, i still would be glad if anyone could help me, to fix my sketch so it makes use of light sleep (what it apparently does not).
Thanks in forward!
By Orcanbull
#52764
For my unterstanding, sleepNow(180) would mean an delay of 3 Minutes. In fact, 180000 actually is about 4 Minutes? At least that´s the time Thingspeak receives an update from DHT/ESP.
What to do to get an Delay of 15 Min. or more? With higher MILI-Values the script stops working.
Thanks!
PS: Script running...will see how long it lasts :)
You actually enter milliseconds, orrigionally you should enter microseconds, the *1000 just converts it to milli seconds, so 180000 milliseconds it what you enter right now.
For a bigger delay you have to just do multiple sleeps in series, there is something about the watchdogtimer that overflows, i think there is a way to disable that.
By JerryESPN
#52874
Tried
Code: Select allsleepNow(120000);
delay(100);
sleepNow(120000);
delay(100);
sleepNow(120000);
delay(100);
and
sleepNow(120000);
sleepNow(120000);
Neither worked. Maybe any more hints on this Watchdog-Thing?
Thanks in forward
Chris
By schufti
#52892 in sleepNow mili is defined as "int" how do you expect it to hold 120000 ???
So try a serial.println(mili) in sleepNow to see how long the sleep will actually be.
