By Syed Niamath
#54600 Thanks for the response. Sorry for the delay in getting back to you.
@Rudy, Please ignore the image, as mentioned in my post that I was a able to successfully run the sketch of WifiScan and can see all the networks around me. I was using ESP8266 with Arduino IDE to program and upload the sketch.
The only problem I am having is not able to print my local IP, I am running the below program through Arduino IDE. Since, this being a key thing for connecting my wifi I tried different ESP8266 with no results.
When I tried Putty with serial connection type selected for AT command the console didn't return anything .
Is this could be something related to my WIFI router ?
// Import required libraries
#include "ESP8266WiFi.h"
// WiFi parameters
const char* ssid = "your_wifi_name";
const char* password = "your_wifi_password";
void setup(void)
// Start Serial
// Connect to WiFi
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
// Print the IP address
