NOVAGENIO wrote:No, I don't have any pullups. For what? In other proyect with pca9685 nevwer use that.
The PCA9685 have 5 pines, VCC, GND, conected to external power (5v) and SDA, SCL, connected to nodemcu module. And the aditional power v+ and gnd to external 5v power.
Here example, connected to a UNO:
http://www.naylampmechatronics.com/modu ... efault.jpg
Pull-ups are probably included on the PCA9685 board. If that is the case then that is why you probably have not needed them. But most of the time a 4k7 - 10k resistor is included. That is adequate for most situations. I typically use 2k2 in order to make sure that capacitance will not have much effect on the rise time of the I2C signals.
Pull ups are required. Maybe they are on the board you are using. If not then they must be added. I2C relies on the pull-ups to produce a high. The chips will produce a low only. This allows more than one device to be connected to the same lines.
