EDIT:
I just ran the code at https://github.com/squix78/esp8266-proj ... logger.ino
Putting in my key and hard-coding some values, GETing every 60 seconds, and I can only connect once successfully.
The modified code (- keys):
* This sketch sends data via HTTP GET requests to thingspeak service every 10 minutes
* You have to set your wifi credentials and your thingspeak key.
extern "C" {
#include "user_interface.h"
const char* ssid = "Virgin Mobile 4G_38AB4B";
const char* password = "XXX";
const char* host = "api.thingspeak.com";
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
delay(5000);
int value = 0;
++value;
logThingSpeak(value);
delay(60000);
void logThingSpeak(int value) {
Serial.println(host);
WiFiClient client;
const int httpPort = 80;
return;
String url = "/update?api_key=XXX&field1=" + String(value);
Serial.println(url);
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
delay(10);
while (client.available()) {
Serial.print(line);
Serial.println("closing connection. ");
Serial output:
Opening port
Port open
Connecting to Virgin Mobile 4G_38AB4B
WiFi connected
IP address:
192.168.0.134
connecting to api.thingspeak.com
Requesting URL: /update?api_key=XXX&field1=1
closing connection.
connection failed
connection failed
connection failed
connection failed
The same result if I GET every 2 minutes.
