testmyesp (dot) dynalias (dot) com : 8099
Explore... Chat... Share...
weekendguy wrote:@tele_player: I think I have stumbled on the area of the problem and it seems to be MTU size related. I modified the html size and found that when "size" as presented in the html header is 1458 it works, but it fails at 1468. I am assuming that at some point around 1460 the stack will need to break up the data into multiple packets which does not appear to be happening. I can PM you my outside address if you would be willing to hit my environment. That will help determine if it's mobile carrier related or connected to my firewall settings in some way. Your help is appreciated! EDIT: Can't find a way to send a PM(!) Please hit my esp with here:
