I'll give it a try, if I can find some time this weekend
I´ve got the ESP 8266 - (1) with 8 Pins --> GPIO2 and GPIO0
If I use -
system_deep_sleep_set_option(4);
system_deep_sleep(60000000);
then it looks like, the ESP isn´t going into Deep sleep.
What I am trying to do, is this one with Arduino IDE:
http://www.terenceang.com/archives/31
He says -
One abnormal behaviour with this light is that it will stay triggered if the ESP8266 radio is on, the solution is to put it into deep sleep with the radio off after the message is sent.
But that doesn´t work - I think the deep sleep is not working.
Could you help me understand this?
My Code:
* This sketch sends data via HTTP GET requests to data.sparkfun.com service.
* You need to get streamId and privateKey at data.sparkfun.com and paste them
* below. Or just customize this script to talk to other HTTP servers.
extern "C" {
#include "user_interface.h"
const char* ssid = "ESSID";
const char* password = "PASSWD";
const char* host = "HOMEPAGE";
const char* privateKey = "CODE";
const int buttonPin = 2;
int value;
int buttonstate;
delay(100);
pinMode(buttonPin, INPUT);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
delay(1000);
Serial.println("Aenderung");
Serial.println(host);
WiFiClient client;
const int httpPort = 80;
return;
// We now create a URI for the request
String url = "/";
url += "?id=";
url += privateKey;
url += "&value=";
url += value;
Serial.println(url);
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
delay(10);
while (client.available()) {
// Serial.print(line);
//ESP.deepSleep(50000, WAKE_RF_DISABLED);
greetigs from south germany.
http://www.nodeusb.com
