Ribeiro Santos wrote:If you're using just one SPI device no problem, because CS (chip select) when LOW means this device is ACTIVE (in use).
The TFT should have one pin to control the brightness. Is this your TFT http://forum.arduino.cc/index.php?topic=200126.0? See the link, if it help you with wiring or another tip.
My TFT ili9341 2.4"
http://www.ebay.com/itm/2-4-240x320-SPI ... 1c45aed73b
i use library
https://github.com/esp8266/Arduino/tree ... it_ILI9341
Platform Arduino ide ESP8266
Try 50-60 resistor and write post. Thank you.
