By j0hncc
#22614 Hi folny82,
I assume it does run some before it resets, right?
Since it seems to be a watchdog timer reset I would suggest trying with the LED strips defined as shorter-- for example set numLeds to 20 instead of 170. If that makes the problem completely go away that will tell you something important.
Cheers,
John
By folny82
#22617 In my project I need to reach 512 pixels controlled via ArtNet protocol to the 4 Universe by 128 pixels. I've tried many codes with ESP8266 and I still have the same problem module is always a time reset and do not know what the problem is. :(
