Note that it IS possible to reduce the flash chip to dual IO mode, freeing up a few of those pins for use as GPIO.
Explore... Chat... Share...
The problem is, most of those are used for the flash chip on the ESP, as in you'll crash the ESP8266 if you fiddle with the wrong GPIO.
