tytower, do you know what the correct speed for a DH11 is? 15 doesnt make much difference
For some reason I no longer get any readings.. and constantly get Failed to read from DHT Sensor in my code, not always but 80% of the time....
Code is trivial.. and Im now baffled again..
Ive set the 3rd param to 15.. baffling]
Angelo Santagata wrote:tytower, do you know what the correct speed for a DH11 is? 15 doesnt make much difference
I don't it is trial and error at this stage . There is a default rate set in the code I think . You will have to look it up . There is also a thread with a few posts on DHT22 and speeds . If I find it I'll post back. From memory I tried from 6 to about 40 and settled on 15 as did someone else in that thread.
