By matkar
#24390 Thank you martinayotte, mine is 1.0.1_15_05_04_p1. So not the latest.
Does anybody have a newer version than this?
How to upgrade to 1.2.0?
Is it even possible to upgrade manually (e.g. overwriting existing SDK folder with newer one) or is igrr the only one who can do this?
By martinayotte
#24394 Yours is 1.6.4-673-g8cd3697.
The current stable is pointing to http://arduino.esp8266.com/versions/1.6 ... index.json which use the SDK 1.2.0_15_07_03
I had the 1.6.5-804-g2d340c7, so I've updated with the above one. But, just in case to avoid conflicts, I had to delete the previous folder 1.6.5-804-g2d340c7 before restarting the IDE.
By matkar
#24579 martinayotte thank you again.
I have successfully updated to the latest SDK. I have noticed with the new SDK same sketch uses substantially more space (70% of flash) than with the old one (47%).
The reason I wanted the latest SDK is to see if the bug I've described here: viewtopic.php?f=32&t=4072 still exists in the newest version...
Regards,
Mat
