By kolban
#25196 Howdy Ben,
I am on the road today but hope to write this up in full by the weekend. There were a couple of tweaks and I think you hit about half of them.
I used Arduino IDE 1.6.5-r2 ... the Arduino Eclipse package didn't like "-r2" and I had to remove that from the version text. I also had to tell the tool where a version of "Make" could be found ... and there were about half a dozen other tweaks. The bottom line is that once it works, it works great ... and I'm sorry to have to make you wait for what I learned ... but I got tired last night and gota work the next two days ... if you can hold off till later ... I promise to have a full write up by the weekend.
Neil
By kolban
#25243 Howdy chums,
Here is the first pass at a write-up. Have a bash and let me know if you have any errors, problems or things just aren't clear.
Neil
(see PDF attachment).
By folny82
#25264 Hi
At compile time I got this error in what can be a problem ?.
Code: Select all10:56:54 **** Incremental Build of configuration Release for project blink ****
"C:\\MinGW\\bin\\mingw32-make" all
Building file: ../.ino.cpp
Starting C++ compile
"/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-I/tools/sdk//include" -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=165-r2 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_1.6.5-990-GC8A63CE  -DESP8266   -I"C:\Users\Folny\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-990-gc8a63ce\cores\esp8266" -I"C:\Users\User\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-990-gc8a63ce\variants\generic" -MMD -MP -MF".ino.cpp.d" -MT".ino.cpp.d" -D__IN_ECLIPSE__=1 -x c++ "../.ino.cpp"  -o  ".ino.cpp.o"   -Wall
/usr/bin/sh: /bin/xtensa-lx106-elf-g++: No such file or directory
subdir.mk:24: recipe for target '.ino.cpp.o' failed
mingw32-make: *** [.ino.cpp.o] Error 127
10:56:55 Build Finished (took 1s.105ms)
