The library can be found at https://github.com/plerup/espsoftwareserial.
Enjoy!
Explore... Chat... Share...
SurfCoders wrote:Peter Lerup has created a SoftwareSerial library that is compatible with the ESP8266.It should be noted that although this code does disable interrupts during transmission and reception of each character, non-maskable interrupts may still occur and such interrupts might affect the bit timing periodically. With that in mind, it would be better to choose a lower baud rate rather than a higher one because the time disturbance of NMI servicing would represent a smaller percentage of a bit time at a lower baud rate. On the other hand, higher baud rates are preferred because the shorter bit time requires interrupts to be disabled for shorter periods of time.
