Also this one about ACS712 shows you ways to properly scale your sensor Output Voltage to meet your ADC input requirements
Available on Tindie: https://www.tindie.com/products/nEXT_EVO1/universal-ac-mains-dimmer-mpdmv41/
Explore... Chat... Share...
WereCatf wrote:pomelo wrote:They claim it outputs 0v to 5v,
ESP8266 has AD0 for 1v.
What value should i expect on AD0 if SHARP MAXES OUT(5v)?
Anything above 1.0V would obviously result in a reading of 1024, you need a voltage divider to bring the sensor's voltage-output into 0V-1.0V - range.
pomelo wrote:Why do i have values at 0 - 115 in analogread(A0) even when the Dust sensor is MAXed ?
i was never able to see 1024 in analogRead(A0) even when i maxed out the sensor by puffing a cigarette smoke into it..
pomelo wrote:WereCatf wrote:pomelo wrote:They claim it outputs 0v to 5v,
