http://www.ebay.es/itm/4-x-Panasonic-en ... 1688779178
Explore... Chat... Share...
Barnabybear wrote:Hi, I think you need to post some schematics and code. I have a project that is nearly complete (has to be by next weekend) that is using an ESP to receive UDP packets and then display them on a 7 x 5 WS2812b matrix. As this is a wearable it runs from 3 AAA batteries. From test with 50% of the WS on at any time at a brightness of 32/255 I'm getting 6 hours running time. If just reading sensors your batteries are failing in less than a day you are doing something fundamentally wrong.
