viewtopic.php?p=31921#p31921
-- but this is not the ILI9325DS as used in the TFTv2.cpp TFT::TFTinit
sendCMD(0x01);
delay(200);
sendCMD(0xCF);
WRITE_DATA(0x00);
WRITE_DATA(0x8B);
WRITE_DATA(0X30);
sendCMD(0xED);
WRITE_DATA(0x67);
WRITE_DATA(0x03);
WRITE_DATA(0X12);
WRITE_DATA(0X81);
sendCMD(0xE8);
WRITE_DATA(0x85);
WRITE_DATA(0x10);
WRITE_DATA(0x7A);
u.s.w.
On this place you have to copy/paste the init-sequenz for your display ..
You have an ILI9341(as "Oldmicroguy" mentioned) ..
.. and to rewrite the init-seq
static const ucg_pgm_uint8_t ucg_tft_240x320_ili9341_init_seq[] = {
UCG_CFG_CD(0,1), /* DC=0 for command mode, DC=1 for data and args */
UCG_RST(1),
UCG_CS(1), /* disable chip */
UCG_DLY_MS(5),
UCG_RST(0),
UCG_DLY_MS(5),
UCG_RST(1),
UCG_DLY_MS(50),
UCG_CS(0), /* enable chip */
UCG_C10(0x011), /* sleep out */
UCG_DLY_MS(10),
//UCG_C10(0x038), /* idle mode off */
UCG_C10(0x013), /* normal display on */
//UCG_C14(0x0ed, 0x055, 0x001, 0x023, 0x001), /* power on sequence control (POR values) */
//UCG_C11(0x0f7, 0x020), /* pump ratio control (POR value) */
UCG_C10(0x20), /* not inverted */
//UCG_C10(0x21), /* inverted */
UCG_C11(0x03a, 0x066), /* set pixel format to 18 bit */
//UCG_C11(0x03a, 0x055), /* set pixel format to 16 bit */
//UCG_C12(0x0b1, 0x000, 0x01b), /* frame rate control (POR values) */
UCG_C14(0x0b6, 0x00a, 0x082 | (1<<5), 0x027, 0x000), /* display function control (POR values, except for shift direction bit) */
//UCG_C11(0x0b7, 0x006), /* entry mode, bit 0: Low voltage detection control (0=off) */
UCG_C11(0x0c0, 0x021), /* power control 1 (reference voltage level), POR=21 */
UCG_C11(0x0c1, 0x002), /* power control 2 (step up factor), POR=2 */
UCG_C11(0x0c7, 0x0c0), /* VCOM control 2, enable VCOM control 1 */
UCG_C12(0x0c5, 0x031, 0x03c), /* VCOM control 1, POR=31,3C */
UCG_C15(0x0cb, 0x039, 0x02c, 0x000, 0x034, 0x002), /* power control A (POR values) */
UCG_C13(0x0cf, 0x000, 0x081, 0x030), /* power control B (POR values) */
UCG_C13(0x0e8, 0x084, 0x011, 0x07a), /* timer driving control A (POR values) */
UCG_C12(0x0ea, 0x066, 0x000), /* timer driving control B (POR values) */
//UCG_C12(0x0ea, 0x000, 0x000), /* timer driving control B */
//UCG_C10(0x28), /* display off */
//UCG_C11(0x0bf, 0x003), /* backlight control 8 */
UCG_C10(0x029), /* display on */
//UCG_C11(0x051, 0x07f), /* brightness */
//UCG_C11(0x053, 0x02c), /* control brightness */
//UCG_C10(0x028), /* display off */
UCG_C11( 0x036, 0x008),
UCG_C14( 0x02a, 0x000, 0x000, 0x000, 0x0ef), /* Horizontal GRAM Address Set */
UCG_C14( 0x02b, 0x000, 0x000, 0x001, 0x03f), /* Vertical GRAM Address Set */
UCG_C10( 0x02c), /* Write Data to GRAM */
UCG_END(), /* end of sequence */
-- where UCG_C10 is to replace with sendCMD;
UCG_C11 --> sendCMD(); WRITE_DATA();
UCG_C12 --> sendCMD();WRITE_DATA();WRITE_DATA();
u.s.w.
sorry, -- a lot of writing ..
or you try this:
case ILI9341_S4P:
LCD_Write_COM(0x11);//sleep out
delay(20);
//LCD_Write_COM(0x01); //reset
//delay(15);
LCD_Write_COM(0x28); //display off
delay(5);
LCD_Write_COM(0xCF); //power control b
LCD_Write_DATA(0x00);
LCD_Write_DATA(0x83); //83 81 AA
LCD_Write_DATA(0x30);
LCD_Write_COM(0xED); //power on seq control
LCD_Write_DATA(0x64); //64 67
LCD_Write_DATA(0x03);
LCD_Write_DATA(0x12);
LCD_Write_DATA(0x81);
LCD_Write_COM(0xE8); //timing control a
LCD_Write_DATA(0x85);
LCD_Write_DATA(0x01);
LCD_Write_DATA(0x79); //79 78
LCD_Write_COM(0xCB); //power control a
LCD_Write_DATA(0x39);
LCD_Write_DATA(0X2C);
LCD_Write_DATA(0x34);
LCD_Write_DATA(0x02);
LCD_Write_COM(0xF7); //pump ratio control
LCD_Write_DATA(0x20);
LCD_Write_COM(0xEA); //timing control b
LCD_Write_COM(0xC0); //power control 2
LCD_Write_DATA(0x26); //26 25
LCD_Write_COM(0xC1); //power control 2
LCD_Write_DATA(0x11);
LCD_Write_COM(0xC5); //vcom control 1
LCD_Write_DATA(0x35);
LCD_Write_DATA(0x3E);
LCD_Write_COM(0xC7); //vcom control 2
LCD_Write_DATA(0xBE); //BE 94
LCD_Write_COM(0xB1); //frame control
LCD_Write_DATA(0x1B); //1B 70
LCD_Write_COM(0xB6); //display control
LCD_Write_DATA(0x0A);
LCD_Write_DATA(0x82);
LCD_Write_DATA(0x27);
LCD_Write_COM(0xB7); //emtry mode
LCD_Write_DATA(0x07);
LCD_Write_COM(0x3A); //pixel format
LCD_Write_DATA(0x55); //16bit
LCD_Write_COM(0x36); //mem access
LCD_Write_DATA((1<<3)|(1<<6));
//LCD_Write_DATA((1<<3)|(1<<7)); //rotate 180
LCD_Write_COM(0x29); //display on
delay(5);
//break;
plus this:
myGLCD.setXY{//case ILI9341_S4P:
LCD_Write_COM(0x2A); //column
LCD_Write_DATA(x1>>8);
LCD_Write_DATA(x1);
LCD_Write_DATA(x2>>8);
LCD_Write_DATA(x2);
LCD_Write_COM(0x2B); //page
LCD_Write_DATA(y1>>8);
LCD_Write_DATA(y1);
LCD_Write_DATA(y2>>8);
LCD_Write_DATA(y2);
LCD_Write_COM(0x2C); //write
}//break;
and this in the setup:
myGLCD.setXY(0, 0, 240, 320); // hinzu
