By PaulRB
#26983 I tried to install IDE 1.6.3, but with this version I could not get Board Manager to work at all. When it attempted to refresh its list of packages, I got "No internet connection available" messages appearing on the staus bar at the bottom of Board Manager's window, and I could not select the esp package to install it. There was nothing wrong with my internet connection at the time.
I have been trying to think what else could be the problem I have here.
BarnabyBear's esp01, into which he uploaded a simple sketch, runs fine for me, on the same breadboard circuit that I was failing with. The esp01 I sent him, he was able to upload sketches to and they run for him. So nothing wrong with the esp01, breadboard circuit or breadboard adaptor.
I have tried 2 machines running linux with IDE 1.6.4 and 1.6.3. I have tried win7 but I cant upload with that. I also can't re-flash the AT command firmware with esptool.
Is it possible there is a problem with my usb serial adaptor? It worked 3 weeks ago, but could it have partially failed because I was overloading its 3.3V output? This feels like clutching at straws, but its 3 weeks since I last got a sketch to run on my esp01.
By martinayotte
#26985 Hi PaulRB,
Code: Select allSketches compile again with 1.6.5
In this case, forget any other versions. Simply stick with this setup. ;)
Code: Select allIs it possible there is a problem with my usb serial adaptor?
Possible ... Enable Verbose in Preferences and tell us what the errors you are getting... :ugeek:
By PaulRB
#27026
martinayotte wrote:Hi PaulRB,
OK here it comes. Thanks for looking at this Martin.
Code: Select allBuild options changed, rebuilding all
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /tmp/build235381338919422257.tmp/sketch_aug21a.cpp -o /tmp/build235381338919422257.tmp/sketch_aug21a.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -g -x assembler-with-cpp -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/cont.S -o /tmp/build235381338919422257.tmp/cont.S.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/core_esp8266_timer.c -o /tmp/build235381338919422257.tmp/core_esp8266_timer.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/spiffs/spiffs_cache.c -o /tmp/build235381338919422257.tmp/spiffs_cache.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/spiffs/spiffs_nucleus.c -o /tmp/build235381338919422257.tmp/spiffs_nucleus.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/spiffs/spiffs_check.c -o /tmp/build235381338919422257.tmp/spiffs_check.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/spiffs/spiffs_hydrogen.c -o /tmp/build235381338919422257.tmp/spiffs_hydrogen.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/spiffs/spiffs_gc.c -o /tmp/build235381338919422257.tmp/spiffs_gc.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/core_esp8266_wiring_digital.c -o /tmp/build235381338919422257.tmp/core_esp8266_wiring_digital.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/core_esp8266_si2c.c -o /tmp/build235381338919422257.tmp/core_esp8266_si2c.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/core_esp8266_wiring_analog.c -o /tmp/build235381338919422257.tmp/core_esp8266_wiring_analog.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/core_esp8266_postmortem.c -o /tmp/build235381338919422257.tmp/core_esp8266_postmortem.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/core_esp8266_flash_utils.c -o /tmp/build235381338919422257.tmp/core_esp8266_flash_utils.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/core_esp8266_wiring.c -o /tmp/build235381338919422257.tmp/core_esp8266_wiring.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/core_esp8266_wiring_pwm.c -o /tmp/build235381338919422257.tmp/core_esp8266_wiring_pwm.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/core_esp8266_wiring_pulse.c -o /tmp/build235381338919422257.tmp/core_esp8266_wiring_pulse.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/core_esp8266_noniso.c -o /tmp/build235381338919422257.tmp/core_esp8266_noniso.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/libc_replacements.c -o /tmp/build235381338919422257.tmp/libc_replacements.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/core_esp8266_i2s.c -o /tmp/build235381338919422257.tmp/core_esp8266_i2s.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/core_esp8266_eboot_command.c -o /tmp/build235381338919422257.tmp/core_esp8266_eboot_command.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/core_esp8266_phy.c -o /tmp/build235381338919422257.tmp/core_esp8266_phy.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/core_esp8266_wiring_shift.c -o /tmp/build235381338919422257.tmp/core_esp8266_wiring_shift.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/cont_util.c -o /tmp/build235381338919422257.tmp/cont_util.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/WMath.cpp -o /tmp/build235381338919422257.tmp/WMath.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/WString.cpp -o /tmp/build235381338919422257.tmp/WString.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/core_esp8266_main.cpp -o /tmp/build235381338919422257.tmp/core_esp8266_main.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/HardwareSerial.cpp -o /tmp/build235381338919422257.tmp/HardwareSerial.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/abi.cpp -o /tmp/build235381338919422257.tmp/abi.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/Esp.cpp -o /tmp/build235381338919422257.tmp/Esp.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/Updater.cpp -o /tmp/build235381338919422257.tmp/Updater.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/IPAddress.cpp -o /tmp/build235381338919422257.tmp/IPAddress.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/pgmspace.cpp -o /tmp/build235381338919422257.tmp/pgmspace.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/debug.cpp -o /tmp/build235381338919422257.tmp/debug.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/Print.cpp -o /tmp/build235381338919422257.tmp/Print.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/Stream.cpp -o /tmp/build235381338919422257.tmp/Stream.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//include -c -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10605 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DESP8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266 -I/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/variants/generic /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/Tone.cpp -o /tmp/build235381338919422257.tmp/Tone.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/cont.S.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/core_esp8266_timer.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/spiffs_cache.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/spiffs_nucleus.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/spiffs_check.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/spiffs_hydrogen.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/spiffs_gc.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/core_esp8266_wiring_digital.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/core_esp8266_si2c.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/core_esp8266_wiring_analog.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/core_esp8266_postmortem.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/core_esp8266_flash_utils.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/core_esp8266_wiring.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/core_esp8266_wiring_pwm.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/core_esp8266_wiring_pulse.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/core_esp8266_noniso.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/libc_replacements.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/core_esp8266_i2s.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/core_esp8266_eboot_command.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/core_esp8266_phy.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/core_esp8266_wiring_shift.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/cont_util.c.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/WMath.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/WString.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/core_esp8266_main.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/HardwareSerial.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/abi.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/Esp.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/Updater.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/IPAddress.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/pgmspace.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/debug.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/Print.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/Stream.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-ar cru /tmp/build235381338919422257.tmp/core.a /tmp/build235381338919422257.tmp/Tone.cpp.o
/home/paul/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc -g -Os -nostdlib -Wl,--no-check-sections -u call_user_start -Wl,-static -L/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//lib -L/home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//ld -Teagle.flash.512k.ld -Wl,-wrap,system_restart_local -Wl,-wrap,register_chipv6_phy -o /tmp/build235381338919422257.tmp/sketch_aug21a.cpp.elf -Wl,--start-group /tmp/build235381338919422257.tmp/sketch_aug21a.cpp.o /tmp/build235381338919422257.tmp/core.a -lm -lgcc -lhal -lphy -lnet80211 -llwip -lwpa -lmain -lpp -lsmartconfig -lwps -lcrypto -Wl,--end-group -L/tmp/build235381338919422257.tmp
/home/paul/.arduino15/packages/esp8266/tools/esptool/0.4.5/esptool -eo /home/paul/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/bootloaders/eboot/eboot.elf -bo /tmp/build235381338919422257.tmp/sketch_aug21a.cpp.bin -bm dio -bf 40 -bz 512K -bs .text -bp 4096 -ec -eo /tmp/build235381338919422257.tmp/sketch_aug21a.cpp.elf -bs .irom0.text -bs .text -bs .data -bs .rodata -bc -ec
Sketch uses 207,296 bytes (47%) of program storage space. Maximum is 434,160 bytes.
Global variables use 44,812 bytes (54%) of dynamic memory, leaving 37,108 bytes for local variables. Maximum is 81,920 bytes.
/home/paul/.arduino15/packages/esp8266/tools/esptool/0.4.5/esptool -vv -cd ck -cb 115200 -cp /dev/ttyUSB0 -ca 0x00000 -cf /tmp/build235381338919422257.tmp/sketch_aug21a.cpp.bin
esptool v0.4.5 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
   setting board to ck
   setting baudrate from 115200 to 115200
   setting port from /dev/ttyUSB0 to /dev/ttyUSB0
   setting address from 0x00000000 to 0x00000000
   espcomm_upload_file
   stat /tmp/build235381338919422257.tmp/sketch_aug21a.cpp.bin success
opening port /dev/ttyUSB0 at 115200
   tcgetattr
   tcsetattr
   serial open
opening bootloader
resetting board
trying to connect
   setting character timeout 0
   done
   setting character timeout 1
   done
   espcomm_send_command: sending command header
   espcomm_send_command: sending command payload
trying to connect
   done
   done
   serialport_receive_C0: 00 instead of C0
trying to connect
   done
   done
   espcomm_send_command: receiving 2 bytes of data
   espcomm_open
Uploading 211440 bytes from /tmp/build235381338919422257.tmp/sketch_aug21a.cpp.bin to flash at 0x00000000
   erasing flash
   size: 0339f0 address: 000000
   first_sector_index: 0
   total_sector_count: 52
   head_sector_count: 16
   adjusted_sector_count: 36
   adjusted_size: 024000
   setting timeout 10000
   setting character timeout 100
   done
   setting timeout 1
   done
   writing flash
starting app without reboot
closing bootloader
Here is the sketch that was compiled & uploaded. It does not run.
Code: Select allvoid setup() {
  Serial.println("Hello");
By martinayotte
#27029 Remembering that you've done an exchange of ESP modules with Barnabybear, and many other trials, I'm start running out if ideas ...
Let's then exchange some serial_test.bin to figure out if compile results are broken or if it is the uploads ...
Please, send yours, I will try it on on of my ESPs.
