By ehaddad
#51142
lotus49 wrote:I have now incorporated this into my program in which I need to verify an RFC6238 TOTP token and I can confirm that it works perfectly.
Thank you once again for your help.
Can you share with us your totp code plZ
Thank you
By lotus49
#51353 I don't promise the code is very pretty. I'm rather out of practice but it does work.
By ehaddad
#51360
#include <WiFiUdp.h>
#include <Wire.h>
#include "Sodaq_DS3231.h"
#include "sha1.h"
#include "TOTP.h"
// ----- User changes begin -----
/// Your network SSID (name)
const char ssid[] = "**********";
/// your network password
const char pass[] = "***********";
/// NTP Server address
const char* ntpServerName = "0.de.pool.ntp.org";
* @brief Timezone
* For CEST use 2.0
const double timezone = -4.0;
// ----- User changes end -----
uint8_t hmacKey[] = {0x61, 0x62, 0x63, 0x64, 0x65, 0x66, 0x67, 0x68, 0x69, 0x6a};
TOTP totp = TOTP(hmacKey, 10);
char code[7];
/// Weekday strings.
char weekDay[][4] = {"Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat"};
// local port to listen for UDP packets
const unsigned int localPort = 2390;
* @brief NTP Server IP variable.
* Don't hardwire the IP address or we won't get the benefits of the pool.
IPAddress timeServerIP;
/// NTP time stamp is in the first 48 bytes of the message
const int NTP_PACKET_SIZE = 48;
/// buffer to hold incoming and outgoing packets
byte packetBuffer[ NTP_PACKET_SIZE];
/// A UDP instance to let us send and receive packets over UDP
WiFiUDP udp;
// send an NTP request to the time server at the given address
void sendNTPpacket(IPAddress *address)
Serial.println("sending NTP packet...");
// set all bytes in the buffer to 0
memset(packetBuffer, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
// (see URL above for details on the packets)
packetBuffer[0] = 0b11100011; // LI, Version, Mode
packetBuffer[1] = 0; // Stratum, or type of clock
packetBuffer[2] = 6; // Polling Interval
packetBuffer[3] = 0xEC; // Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
packetBuffer[12] = 49;
packetBuffer[13] = 0x4E;
packetBuffer[14] = 49;
packetBuffer[15] = 52;
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
udp.beginPacket(*address, 123); //NTP requests are to port 123
udp.write(packetBuffer, NTP_PACKET_SIZE);
udp.endPacket();
* @brief Adjust the DS3231 with current date and time.
* <pre>
* NTPv4 Basic Header Specification:
* Bytes : Description
* 0: LI(2), VN(3), Mode(3)
* 1: Stratum
* 2: Poll
* 3: Precision
* 4 - 7: Root Delay
* 8 - 11: Root Dispersion
* 12 - 15: Reference ID
* 16 - 23: Reference Timestamp
* 24 - 31: Origin Timestamp
* 32 - 39: Receive Timestamp
* 40 - 47: Transmit Timestamp
* Transmit Timestamp:
* Time at the server when the response left for the client, in NTP timestamp format.
* NTP timestamp format
* Bytes: Description
* 0 - 3: Seconds since 1900
* 4 - 7: Fraction of Second
* </pre>
static inline void adjust(void)
unsigned long mi;
int cb = 0;
//get a random server from the pool
WiFi.hostByName(ntpServerName, timeServerIP);
// send an NTP packet to a time server
sendNTPpacket(&timeServerIP);
mi = millis();
// wait to see if a reply is available
while (millis() - mi < 2000 && !cb)
cb = udp.parsePacket();
yield();
if (!cb)
Serial.println("[ERROR]: No packet available.");
return;
//Serial.print("packet received, length=");
//Serial.println(cb);
// We've received a packet, read the data from it
udp.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
//the timestamp starts at byte 40 of the received packet and is four bytes,
// or two words, long. First, esxtract the two words:
unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
// combine the four bytes (two words) into a long integer
// this is NTP time (seconds since Jan 1 1900):
unsigned long secsSince1900 = highWord << 16 | lowWord;
//Serial.print("Seconds since Jan 1 1900 = " );
//Serial.println(secsSince1900);
// now convert NTP time into everyday time:
Serial.print("Unix UTC time = ");
// Unix time starts on Jan 1 1970. In seconds, that's 2208988800:
const unsigned long seventyYears = 2208988800UL;
// subtract seventy years:
unsigned long epoch = secsSince1900 - seventyYears;
// print Unix time:
Serial.println(epoch);
// adjust to user timezone
epoch += timezone * 3600;
rtc.setEpoch(epoch);
* @brief Setup function.
void setup ()
// Serial init
// I2C init
Wire.begin();
// RTC init
rtc.begin();
Serial.println("\r\n");
// Connect to your WiFi network.
Serial.println(ssid);
WiFi.begin(ssid, pass);
Serial.print(".");
Serial.println("");
// Start UDP Server to receive the NTP response.
Serial.println("Starting UDP");
udp.begin(localPort);
* @brief Loop function.
void loop ()
static uint16_t lastMillis = 0;
uint16_t currentMillis = millis() / 1000;
if (currentMillis - lastMillis >= 1)
lastMillis = currentMillis;
DateTime now = rtc.now(); //get the current date-time
unsigned long GMT = now.getEpoch();
//Serial.println(GMT);
char* newCode = totp.getCode(GMT);
if(strcmp(code, newCode) != 0) {
Serial.printf("%02d-%02d-%02d ", now.year(), now.month(), now.date());
Serial.printf("%02d:%02d:%02d ", now.hour(), now.minute(), now.second());
Serial.println(weekDay[now.dayOfWeek()]);
Serial.print("Seconds since Unix Epoch: ");
Serial.print(now.getEpoch(), DEC);
strcpy(code, newCode);
Serial.print("TOTP: ");
Serial.println(code);
// handle serial
if (Serial.available())
String message = Serial.readStringUntil('\n');
message.trim();
Serial.print("message: ");
Serial.println(message);
if (message.startsWith("update"))
Serial.println("Update via NTP.");
adjust();
this is my code, the problem is that the OTP code generated by the esp8266 don't match the one given by google authenticator app
UPDATE: solved..... timezone need to be 00 UTC.
