But for now, i´ll try to master modem sleep first, light sleep after that.
Just ordered an USB Multimeter ( https://www.amazon.com/PowerJive-Voltag ... B013FANC9W ) to see if it really works/saves power.
I´m using a LD1117V33 voltage regulator.
My "aim" is, to keep the ESP8266 and a DHT11/22 working for at least 3 Month, with my 3000mAh LiPo this means 1.37mA. Maybe impossible .
The Code i´m currently testing:
#include <DHT.h>
// replace with your channel’s thingspeak API key,
String apiKey = "EQWRTWERWRTZWR";
const char* ssid = "WERGWERG";
const char* password = "123452345234534";
const char* server = "api.thingspeak.com";
#define DHTPIN 2 // what pin we’re connected to
DHT dht(DHTPIN, DHT11,15);
WiFiClient client;
// Required for LIGHT_SLEEP_T delay mode
//extern "C" {
//#include "user_interface.h"
delay(10);
dht.begin();
WiFi.mode(WIFI_STA); // added 230716
WiFi.begin(ssid, password);
Serial.println(ssid);
Serial.print(".");
Serial.println("");
float h = dht.readHumidity();
float t = dht.readTemperature();
if (isnan(h) || isnan(t)) {
return;
if (client.connect(server,80)) { // "184.106.153.149" or api.thingspeak.com
String postStr = apiKey;
postStr +="&field1=";
postStr += String(t);
postStr +="&field2=";
postStr += String(h);
postStr += "\r\n\r\n";
client.print("POST /update HTTP/1.1\n");
client.print("Host: api.thingspeak.com\n");
client.print("Connection: close\n");
client.print("X-THINGSPEAKAPIKEY: "+apiKey+"\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(postStr.length());
client.print("\n\n");
client.print(postStr);
Serial.print("Temperature: ");
Serial.print(t);
Serial.print(" degrees Celcius Humidity: ");
Serial.print(h);
Serial.println("% send to Thingspeak");
client.stop();
Serial.println("Waiting…");
// thingspeak needs minimum 15 sec delay between updates
//wifi_set_sleep_type(LIGHT_SLEEP_T);
WiFi.forceSleepBegin();
delay(900000);
WiFi.forceSleepWake();
delay(5);
Please forgive "dirty" code, i´ll take care of that later.
