schufti wrote:...as your existing code goes through setup once and then keeps "looping" (and creating a wifi client) every 5min, I would suggest to at least move the
// Define a new client
WiFiClient client;
to the setup section (out of the loop).
I am pretty sure this was causing the locking, removing it like in below code, made it run for over 24 hours already, using a (5 min) pause at the end of the loop.
But the deepsleep makes sence as well, so instead of a pause, i've updated my code to the below;
schufti wrote:an esp.restart() will just restart the esp8266 but without a reinitialisation of the hw (cantrary to power up or reset), meaning: will go through setup and then enter loop. Deepsleep wakeup the esp8266 starts up like hw-reset (with all init of ports, registers etc)
The (updated) code with the deepsleep, intended as a (5 min = 300 seconds) cycle;
#include <DHT.h>
#include <BH1750.h>
const int sleepTimeS = 300; // seconds to sleep between every cycle
// ========================= LED PIN ========================
#define LED_PIN D5 // Led pin
// ======================= DHT11 / 22 =======================
#define DHTPIN D3
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
// ==================== lightmeter BH1750 ===================
// BH1750 Light Sensor connection: VCC to 5v+ | GND to GND | SCL to pin SCL/D1 | SDA to pin SDA/D2 | ADD not used
BH1750 lightMeter;
// ========================== Wifi ==========================
const char* ssid = "myssid";
const char* password = "mypass";
// ============= Domoticz host address and port =============
const char* host = "192.168.2.100"; // NOTE: There should not be http:// before the address!!!
const int httpPort = 8080;
// =============== Domoticz devices to update ===============
int domoticz_temp_idx = 133;
int domoticz_hum_idx = 167;
int domoticz_lux_idx = 168;
void WIFI_Connect(){
digitalWrite(2,1);
WiFi.disconnect();
Serial.println("Booting Sketch...");
// WiFi.mode(WIFI_AP_STA);
WiFi.begin(ssid, password);
Serial.println(ssid);
// Wait for connection
for (int i = 0; i < 25; i++){
if ( WiFi.status() != WL_CONNECTED ) {
delay ( 250 );
digitalWrite(2,0);
Serial.print ( "." );
delay ( 250 );
digitalWrite(2,1);
digitalWrite(2,0);
Serial.println("");
Serial.print("Device IP: ");
Serial.println("=============================================");
Serial.println("");
void setup(void){
pinMode(2, OUTPUT);
WIFI_Connect();
// starting DHT sensor
dht.begin();
// starting lightMeter BH1750
lightMeter.begin();
void loop(void){
if (WiFi.status() != WL_CONNECTED)
digitalWrite(2,1);
WIFI_Connect();
} else {
digitalWrite(2,0);
Serial.println("Reading sensors:");
// === DHT22 ===
float hum = dht.readHumidity();
float temp = dht.readTemperature();
int hum_status = 0;
if (isnan(hum) || isnan(temp)) {
return;
} else {
// === TEMPERATURE ===
Serial.print("Temperature: ");
Serial.print(temp);
Serial.println(" degrees Celsius");
// When we set a correction...
// Serial.print("After (-4%) correction, temperature is: ");
// temp = temp*0.96; /* 4 precent correction */
// Serial.print(temp);
// Serial.println(" degrees Celsius");
// === HUMIDITY ===
Serial.print("Humidity: ");
Serial.print(hum);
Serial.println(" Percent");
// === BH1750 ===
uint16_t lux = lightMeter.readLightLevel();
int luxnum = lux;
if (isnan(lux)) {
Serial.println("Failed to read from LUX sensor!");
return;
} else {
Serial.print("Lux: ");
Serial.println(lux);
Serial.println("");
Serial.println("Update values in Domoticz:");
WiFiClient client;
unsigned long timeout = millis();
// Get Connected to the Server
Serial.println("[connection failed]");
return;
// LED turns on when we connect
digitalWrite(LED_PIN, HIGH);
Serial.println("Temperature:");
// get url to set temperature
String url = gettempurl(temp, domoticz_temp_idx);
Serial.println(url);
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
// set the timeout value
int TIMEOUT1 = millis() + 5000;
while(client.available() == 0){
// check for timeout
if (TIMEOUT1 - millis() < 0) {
Serial.println(">>> CLIENT TIMEOUT!");
// Before we exit, turn the LED off.
digitalWrite(LED_PIN, LOW);
client.stop();
return;
Serial.print(line);
// Disconnect from the server
client.stop();
Serial.println("");
// === HUMIDITY ===
return;
Serial.println("Humidity:");
/* -- Mapping for Humidity_status
-- 0 = Normal
-- 1 <> 46-70% = Comfortable
-- 2 < 46 = Dry
-- 3 > 70% = Wet
if (hum > 0){
if ((hum >= 46) and (hum <= 70)) {
hum_status = 1; /* comfortable */
} else if (hum < 46) {
hum_status = 2; /* dry */
} else if (hum > 70)
hum_status = 3; /* wet */
// get url to set humidity
String url_hum = gethumurl(hum, hum_status, domoticz_hum_idx);
Serial.println(url_hum);
client.print(String("GET ") + url_hum + " HTTP/1.1\r\n" +
int TIMEOUT2 = millis() + 5000;
if (TIMEOUT2 - millis() < 0) {
client.stop();
return;
Serial.print(line);
client.stop();
Serial.println("");
// === LUX ===
return;
Serial.println("Lux:");
String url_lux = getluxurl(lux, domoticz_lux_idx);
Serial.println(url_lux);
client.print(String("GET ") + url_lux + " HTTP/1.1\r\n" +
int TIMEOUT3 = millis() + 5000;
if (TIMEOUT3 - millis() < 0) {
client.stop();
return;
Serial.print(line);
Serial.println("");
client.stop();
Serial.println("");
// === SLEEP ===
Serial.println("ESP8266 in sleep mode");
Serial.println("");
ESP.deepSleep(sleepTimeS * 1000000); //sleep time, seconds to usecs.
delay(1000); // a short delay to keep in loop while ESP.deepSleep() is being implemented.
String gettempurl(int temperature, int idx){
// this function returns url to set temp_value in domoticz
/* example url for domoticz temperature device:
http://192.168.2.100:8080/json.htm?type=command¶m=udevice&idx=133&nvalue=0&svalue=24
// Create a URI for the request
String url = "/json.htm?type=command¶m=udevice&idx=";
url += idx;
url += "&nvalue=0&svalue=";
url += temperature;
return url;
String gethumurl(int humidity, int humstatus, int idx){
// this function returns url to set hum_value in domoticz
/* example url for domoticz humidity device:
http://192.168.2.100:8080/json.htm?type=command¶m=udevice&idx=IDX&nvalue=HUM&svalue=0
// We now create a URI for the request
url += idx;
url += "&nvalue=";
url += humidity; // Humidity value
url += "&svalue=";
url += humstatus; // Humidity_status can be: 0=Normal | 1=Comfortable | 2=Dry | 3=Wet
return url;
String getluxurl(int lux, int idx){
// this function returns url to set lux_value in domoticz
/* example url for domoticz lux device:
http://192.168.2.100:8080/json.htm?type=command¶m=udevice&idx=IDX&svalue=VALUE
url += idx;
url += "&svalue=";
url += lux;
return url;
Going to deepsleep showed a nice signoff for the device in my wifi-logging:
5C:CF:XX:XX:XX:XX@wlan1: disconnected, received disassoc: sending station leaving (8)
However, the serial monitor does print a line of garbage, but does that instead of restarting after 5 minutes!
So this never comes alive again after deepSleep()
I looked at this example, where everything is in setup{}, but that makes no difference for me.
Next i found this thread about putting a 1K resister (but even a lower one should work, such 470R or even 220R) between D0 and RST.
