By weekendguy
#70405 @tele_player: I tried mobile wireless on Sprint, VZW, and AT&T and all 3 failed with the current test code (packet size 1468). That's odd because it worked for you on AT&T. I have also attached clean packet traces (in zip file). In both cases I browsed to /inline first to confirm connection, and then "/". It's very clear when you compare the traces that over wifi the larger packet follows but not over mobile. I think in IP rules there are legal times to drop a packet - like when packet sizes break some boundary - so maybe that's what is happening but it sure seems like a solution may lie in the ESP stack somewhere... Please let me know what you think.
packets.zip
By tele_player
#70430 There's a sub-forum here for esp8266 Arduino bug reports, but this one might be tricky to replicate. If I'm reading the traces correctly, deeper digging into the lwip code is needed, to determine why the full HTTP reply is (apparently) not being sent. It's possible there are additional debug features that can be enabled, I haven't looked that deep.
