By danbicks
#21546 Ha ha,
Well done mate, glad to see you are still using my lovely Wifi broadcast image :)
Nice one mate I will have a little play with it.
I hope it is not using Lua :( on that nodemcu lol
Dans
By tao13
#23238 Hi , can you help me with some ideeas?
I received these errors when i want to upload the sketch from arduino IDE to an esp8266( it is a nodemcu 0.9 board)
In file included from C:\Program Files (x86)\Arduino\libraries\Adafruit_GFX\Adafruit_GFX.cpp:35:0:
C:\Program Files (x86)\Arduino\libraries\Adafruit_GFX\glcdfont.c:8:0: warning: "PROGMEM" redefined [enabled by default]
#define PROGMEM
In file included from C:\Users\TAO13\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.4-673-g8cd3697\cores\esp8266/Arduino.h:38:0,
from C:\Program Files (x86)\Arduino\libraries\Adafruit_GFX\Adafruit_GFX.h:5,
from C:\Program Files (x86)\Arduino\libraries\Adafruit_GFX\Adafruit_GFX.cpp:34:
C:\Users\TAO13\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.4-673-g8cd3697\cores\esp8266/pgmspace.h:15:0: note: this is the location of the previous definition
#define PROGMEM ICACHE_RODATA_ATTR
C:\Program Files (x86)\Arduino\libraries\Adafruit_GFX\Adafruit_GFX.cpp:39:0: warning: "pgm_read_byte" redefined [enabled by default]
#define pgm_read_byte(addr) (*(const unsigned char *)(addr))
C:\Users\TAO13\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.4-673-g8cd3697\cores\esp8266/pgmspace.h:63:0: note: this is the location of the previous definition
#define pgm_read_byte(addr) \
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp: In constructor 'Adafruit_ST7735::Adafruit_ST7735(int8_t, int8_t, int8_t, int8_t, int8_t)':
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:39:3: error: '_cs' was not declared in this scope
_cs = cs;
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:40:3: error: '_rs' was not declared in this scope
_rs = rs;
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:41:3: error: '_sid' was not declared in this scope
_sid = sid;
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:42:3: error: '_sclk' was not declared in this scope
_sclk = sclk;
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:43:3: error: '_rst' was not declared in this scope
_rst = rst;
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp: In constructor 'Adafruit_ST7735::Adafruit_ST7735(int8_t, int8_t, int8_t)':
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:52:3: error: '_cs' was not declared in this scope
_cs = cs;
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:53:3: error: '_rs' was not declared in this scope
_rs = rs;
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:54:3: error: '_rst' was not declared in this scope
_rst = rst;
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:56:3: error: '_sid' was not declared in this scope
_sid = _sclk = 0;
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:56:11: error: '_sclk' was not declared in this scope
_sid = _sclk = 0;
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp: In member function 'void Adafruit_ST7735::commonInit(const uint8_t*)':
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:322:3: error: 'colstart' was not declared in this scope
colstart = rowstart = 0; // May be overridden in init func
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:322:15: error: 'rowstart' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:324:11: error: '_rs' was not declared in this scope
pinMode(_rs, OUTPUT);
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:325:11: error: '_cs' was not declared in this scope
pinMode(_cs, OUTPUT);
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:334:3: error: 'cspinmask' was not declared in this scope
cspinmask = digitalPinToBitMask(_cs);
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:335:3: error: 'rspinmask' was not declared in this scope
rspinmask = digitalPinToBitMask(_rs);
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:350:13: error: '_sclk' was not declared in this scope
pinMode(_sclk, OUTPUT);
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:351:13: error: '_sid' was not declared in this scope
pinMode(_sid , OUTPUT);
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:360:5: error: 'clkpinmask' was not declared in this scope
clkpinmask = digitalPinToBitMask(_sclk);
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:361:5: error: 'datapinmask' was not declared in this scope
datapinmask = digitalPinToBitMask(_sid);
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:379:7: error: '_rst' was not declared in this scope
if (_rst) {
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp: In member function 'void Adafruit_ST7735::initR(uint8_t)':
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:404:5: error: 'colstart' was not declared in this scope
colstart = 2;
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:405:5: error: 'rowstart' was not declared in this scope
rowstart = 1;
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:409:5: error: 'colstart' was not declared in this scope
colstart = 2;
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:410:5: error: 'rowstart' was not declared in this scope
rowstart = 3;
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp: In member function 'void Adafruit_ST7735::setAddrWindow(uint8_t, uint8_t, uint8_t, uint8_t)':
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:432:16: error: 'colstart' was not declared in this scope
writedata(x0+colstart); // XSTART
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:438:16: error: 'rowstart' was not declared in this scope
writedata(y0+rowstart); // YSTART
Error compiling.
