How could write the source of the image as given in your code?
Explore... Chat... Share...
String getContentType(String filename) {
yield();
if (server.hasArg("download")) return "application/octet-stream";
else if (filename.endsWith(".htm")) return "text/html";
else if (filename.endsWith(".html"))return "text/html";
else if (filename.endsWith(".css")) return "text/css";
else if (filename.endsWith(".js")) return "application/javascript";
else if (filename.endsWith(".png")) return "image/png";
else if (filename.endsWith(".gif")) return "image/gif";
else if (filename.endsWith(".jpg")) return "image/jpeg";
else if (filename.endsWith(".ico")) return "image/x-icon";
else if (filename.endsWith(".xml")) return "text/xml";
else if (filename.endsWith(".pdf")) return "application/x-pdf";
else if (filename.endsWith(".zip")) return "application/x-zip";
else if (filename.endsWith(".gz")) return "application/x-gzip";
else if (filename.endsWith(".svg")) return "image/svg+xml";
return "text/plain";
