- Thu Jun 28, 2018 9:13 pm
#76711
Your kidding right?
I tried this on my favorite development platform. It uses a ESP-12E. I have GPIO0 and GPIO2 used for I2C communications. I have a level translator on that board so I can reliably drive a 5 volt I2C character LCD. I have leds connected from Vcc to the IO pin.
All of my development boards have ESP-12E. I have lots of ESP-12F waiting but none that I could use to test this. It really should not have mattered, but I was sure you would say that there must be a difference between the E and the F, causing it not to work for you. So I looked for something I had with an F. I then remembered this.
It is a board I designed for work a couple of years ago, but we never got around to developing any software for it. The F had just come out and that is what I purchased for it.
I I loaded the test code and I connected and led from Vcc to GPIO0, and then ran the code. And of course it work just as well as on the E. So I went a lot further than I initially planned.
But then I thought you might say that the pin was only sinking current, and that it would no be able to source current, an led from GPIO0 to gnd. So I connected it all up again and I connected the LED (with series resistor) that way, and of course it worked just fine.
No scope but I did use a DVM to measure the high and low voltage. And the low state goes down to 0.12 volts. High is 3.29 volts, but that is not with it sourcing current.
I don't know what you tried, how you did your tests, but you must have done something wrong. There is no reason for it to not work. If your program is running then it should work.
