So i discovered a way to load Oled XBM Image files From Spiffs Filesystem.
Esp8266 Repo Did not included the Spiffs Upload Tool which is required for making and uploading Files to Esp8266 FileSystem.
To Upload Files to Spiffs (Esp8266 File System) you need esp8266fs.jar Placed like:
Program files/Arduino/tools/ESP8266FS/tool/esp8266fs.jar
Download: https://github.com/esp8266/arduino-esp8 ... -0.2.0.zip
Check Updates: https://github.com/esp8266/arduino-esp8 ... n/releases - See more at: viewtopic.php?f=32&t=10081#sthash.ttZLKIb7.dpuf
Schematics:
Mine Blue OLED Pins:
Gnd > NodeEsp G or Gnd
Vcc > 3V
SCL > D5
SDA > D7
DHT22 Front View Pins on Bottom :
From Left Side:
1: 3V
2: D1
3:Not Used
4: Nodemcu G or Gnd
Power it from Usb and Open Arduino 1.6.5 or Up
The code is a Temperature & Humidity OLED Display and Pushbullet Notifications on Over Temperature.
I have added Code For : DHT22, PushBullet , WifiManager, Oled , SPIFFS.
#include <Wire.h>
#include <SPI.h>
#include <FS.h>
#include "SSD1306.h"
#include "SSD1306Ui.h"
#include <PushBullet.h>
#include <WiFiClientSecure.h>
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include "WiFiManager.h"
#include "DHT.h"
#define PORT 443
int incomingByte = 0;
WiFiClientSecure client;
// PUT YOUR PUSHBULLET API HERE
PushBullet pb = PushBullet("----------API---------------", &client, 443);
// CALLBACK ON AUTOCONFIG
void configModeCallback (WiFiManager *myWiFiManager) {
Serial.println("Entered config mode");
Serial.println(WiFi.softAPIP());
Serial.println(myWiFiManager->getConfigPortalSSID());
//DHT22 ON NODEMCU PIN D1
#define DHTPIN D1
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
// 128x64 OLED ON I2C
#define OLED_SDA D7
#define OLED_SDC D5
#define OLED_ADDR 0x3C
SSD1306 display(OLED_ADDR, OLED_SDA, OLED_SDC); // For I2C
int x = 0;
long lastm = 0;
long lastm1 = 0;
// LOAD DISPLAY
display.init();
display.flipScreenVertically();
Serial.begin(9600);
// LOAD FILESYSTEM
if (!SPIFFS.begin()) {
Serial.println("Failed to mount file system");
File f;
// OPEN FILE (ENTER FILE WITH PATH WIRH SLASH IN FRONT)
f = SPIFFS.open("/file.mono", "r");
if (f) {
int s = f.size();
Serial.printf("File Opened , Size=%d\r\n", s);
String data = f.readString();
//Serial.println(data);
const char* data1 = data.c_str();
f.close();
display.drawXbm(0, 0, 125, 60, data1);
display.display();
//DISPLAY TILL WIFI CONNECTION
} else {
Serial.println("File Not Opened");
// CONNECT WIFI WifiManager (AUTO SETUP)
connect();
//PUSHBULLET CONNECTION
pb.openConnection();
if (!pb.checkConnection()) {
Serial.println("Failed to connect to pushbullet.com");
return;
} else {
Serial.println("Connected to pushbullet.com");
//DHT22 SETUP
dht.begin();
// UPDATE TEMP EVERY 5 SECS
if (((micros() - lastm) / 1000000) > 5 || lastm == 0) {
show();
lastm = micros();
void connect() {
// AUTO WIFI SETUP WITH AP (Connect ESPxxxxx WIFI AP and OPEN 192.168.4.1 AND FILL WIFI PASSWORD)
WiFiManager wifiManager;
wifiManager.setAPCallback(configModeCallback);
Serial.println("Connecting...");
if (!wifiManager.autoConnect()) {
Serial.println("failed to connect and hit timeout");
Serial.println("connected...yeey :)");
bool show() {
// UPDATE OLED TEMP
display.clear();
// Read temperature as Celsius
float t = dht.readTemperature();
//Convert Float to Char
char temp[3];
itoa(t, temp, 10);
// Read Humidity
float h = dht.readHumidity();
char hum[3];
itoa(h, hum, 10);
display.setColor(WHITE);
display.setTextAlignment(TEXT_ALIGN_LEFT);
display.setFont(ArialMT_Plain_16);
display.drawString(10, 10, "Temp Hum");
display.setFont(ArialMT_Plain_24);
display.drawString( 20, 30, temp);
display.drawString( 80, 30, hum);
// CHECK DISPLAY UPDATE
display.setFont(ArialMT_Plain_10);
display.drawString( x, 55, "o");
x++;
if (x > 128)x = 0;
display.display();
// After Every 60 Seconds Check High Temp and send PUSH Notification
if (((micros() - lastm1) / 1000000) > 60 || lastm1 == 0) {
//IF TEMP MORE THAN 32
if (t >= 32) {
//Join Strings
char* str1 = "Temperature: ";
strcat(str1, temp);
// SEND NOTIFICATION
pb.sendNotePush(str1, "Alert");
delay(5000);
lastm1 = micros();
This is what i tried. You can modify the Sizes according to your needs.
Make a image of 125*61 with paint and save it as bmp Monocrome Bitmap.
Visit http://www.online-utility.org/image/convert/to/MONO
Upload this file and make a mono file.
Now Save your sketch, Go to Sketch Data Folder By Pressing Sketch > Show Sketch Folder
Create a new folder and name it "data".
Save this .mono file to this data folder.
Now press Tools > Esp8266 Sketch Data Upload
After completed, Upload the Sketch, Open Serial Monitor and have fun.
