By RogerH
#53449 Hi,
I am programming WEMOS D1 mini's from the Arduino/ESP8266 environment.
Is it possible to setup the board programmer to use DTR and DSR to put the board into flash mode?
Thanks in advance.
By RogerH
#53523 Doh, I am answering my own question....You select the correct board type and it uses the DTR/DSR to put the board into programming mode. I had the Generic ESP82266 selected instead of the WEMOS D1.
