By Toto Nano
#56932 help me, What changed if you want to make esp-01 as client?
I have learned and no found reference.
#include <WiFiClient.h>
#include <Servo.h>
const char *ssid = "mywifi";
const char *pw = "qwerty123";
IPAddress ip(192, 168, 0, 1);
IPAddress netmask(255, 255, 255, 0);
const int port = 9876;
const int chCount = 4;
Servo servoCh[chCount];
int chPin[] = {0, 2, 14, 12};
int chVal[] = {1500, 1500, 1500, 1500};
int usMin = 700;
int usMax = 2300;
WiFiServer server(port);
WiFiClient client;
char cmd[100];
int cmdIndex;
unsigned long lastCmdTime = 60000;
unsigned long aliveSentTime = 0;
boolean cmdStartsWith(const char *st) {
  for(int i=0; ; i++) {
    if(st[i]==0) return true;
    if(cmd[i]==0) return false;
    if(cmd[i]!=st[i]) return false;;
  return false;
void exeCmd() {
  lastCmdTime = millis();
  if( cmdStartsWith("ch") ) {
    int ch = cmd[2] - '0';
    if(ch>=0 && ch<=9 && cmd[3]==' ') {
      chVal[ch] = (int)atof(cmd+4);
      if(!servoCh[ch].attached()) {
        servoCh[ch].attach(chPin[ch], usMin, usMax);
      servoCh[ch].writeMicroseconds(chVal[ch]);
  if( cmdStartsWith("ci") ) {
      chVal[ch] = -(int)atof(cmd+4);
  if( cmdStartsWith("ca") ) {
      chVal[ch] = (usMax+usMin)/2 + (int)( atof(cmd+4)*51 );
  if( cmdStartsWith("cb") ) {
      chVal[ch] = (usMax+usMin)/2 - (int)( atof(cmd+4)*51 );
  delay(1000);
  /*for(int i=0; i<chCount; i++) {
    servoCh[i].attach(chPin[i], usMin, usMax);
    chVal[i] = (usMin + usMax)/2;
    servoCh[i].writeMicroseconds( chVal[i] );
  cmdIndex = 0;
  WiFi.softAPConfig(ip, ip, netmask);
  WiFi.softAP(ssid, pw);
  server.begin();
  Serial.println("ESP8266 RC receiver 1.1 powered by RoboRemo");
  Serial.println((String)"SSID: " + ssid + "  PASS: " + pw);
  Serial.println((String)"RoboRemo app must connect to " + ip.toString() + ":" + port);
  if(millis() - lastCmdTime > 500) {
      servoCh[i].writeMicroseconds( (usMin + usMax)/2 );
      servoCh[i].detach();
  if(!client.connected()) {
    client = server.available();
    return;
  if(client.available()) {
    char c = (char)client.read();
    if(c=='\n') {
      cmd[cmdIndex] = 0;
      exeCmd();
      cmdIndex = 0;
    } else {
      cmd[cmdIndex] = c;
      if(cmdIndex<99) cmdIndex++;
  if(millis() - aliveSentTime > 500) {
    client.write("alive 1\n");
    aliveSentTime = millis();
