By andrept
#58173 Hello everyone,
Recently I started playing with an esp and a lcd but I can not get it to work.
First, I made this http://ediy.com.my/blog/item/133-upload ... rduino-ide and I can turn leds on and off and connect it to my wifi.
When I connect my i2c lcd 16x2 (sda=gpio04;scl=gpio05;vcc=5v), it turns one row dark and the other empty (for what i see on some videos this is normal), I upload the code but nothing works.
I tryed:
- http://www.prometec.net/esp8266-display-i2c/
- https://github.com/agnunez/ESP8266-I2C-LCD1602
- http://imaginen4tion.blogspot.pt/2015/1 ... a-i2c.html
I tested this example(https://github.com/agnunez/ESP8266-I2C- ... I2CLCD.ino) with 2 LED and one blink but the other no (maybe is too fast).
What am I doing wrong?
Thanks!
By rudy
#58190 Do you have pull up resistors on SDA and SCL? Typically I use 4K7 but I will use as low as 2K2. They must be connected to +3.3v and not +5.
There are different I2C LCD adapter boards. There are different wiring on some. I also have some that have the same board but the chip that is on it has a different address. Check the address for the chip you are using and make sure to use that address in your code.
I know all that and when I have to recreate my environment I always have a problem finding a good library. I forget to note where I got it from. The I2C-LCD library I have on my machine at work is Library https://github.com/agnunez/ESP8266-I2C-LCD1602
By andrept
#58201 Thank you Rudy,
The address I think is correct, my I2C board have "A0 A1 A2" with no jumper so it must be "0x27"
I am connecting my GPIO4 and GPIO05 directly on the SDA an SCL.
I will try add the pull up resistors
Thanks
By rudy
#58214
andrept wrote:Thank you Rudy,
There are two versions of the chip. One that uses "0x27" PCF8574 and the other PCF8574A "0x3F". I have had some sent with the PCF8574A and that wasn't in the listing when I bought them.
There are I2C port scanner sketches that come in handy for checking initial setup and communications.
From a web search http://playground.arduino.cc/Main/I2cScanner
