By pidloop
#59721 Hello. I am connecting to a server with WiFiClient. I read using the usual loop with timeout:
Code: Select all        uint32_t t0 = millis();
        while (!cl.available()) {
            if (millis() - t0 > time_out)
                return (false); // timed out before seeing \n
            delay(10);
        int c = cl.read();
This works ok but I must always wait for the timeout to know when connection is finished.
So my question is: Is there a way to know immediately when a connection has been closed by the remote side?
Thank you.
