By Ray Alderman
#62603 All,
So I'm trying to establish a TLS/SSL connection to a server and then making a GET request with a required Auth header.
first attempt at using WiFiClientSecure and first attempt at using ESP8266HTTPClient.
I think I am getting a good TLS connection but the GET request is failing and I get a HTTP response 400,
"400 Bad Request
The server cannot or will not process the request due to an apparent client error"
I need to send the "X-Amt-Auth" header with the long key to show really, I'm allowed to get this data.
could not find an example of using ESP8266HTTPClient to send a GET request with a header. Any suggestions on what I'm doing wrong here?
Code: Select all/*
 *  HTTP over TLS (HTTPS) example sketch
 *  This example demonstrates how to use
 *  WiFiClientSecure class to access HTTPS API.
 *  We fetch and display the status of
 *  esp8266/Arduino project continuous integration
 *  build.
 *  Created by Ivan Grokhotkov, 2015.
 *  This example is in public domain.
#include <WiFiClientSecure.h>
const char* ssid = "xxx";
const char* password = "123";
const char* host = "zzz.org";
const int httpsPort = 443;
String url = "/wp-json/amt/v1/rfids/active";
  Serial.println(ssid);
  // logging into the wifi router
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  // at this point connected to the wifi router
  // Use WiFiClientSecure class to create TLS connection to host server on port httpsPort
  WiFiClientSecure client;
  Serial.println(host);
  if (!client.connect(host, httpsPort)) {
    return;
  // at this point established a TLS connection to the host on port httpsPort
  HTTPClient http;
  delay(100);
  http.begin(host, httpsPort, url);
  http.addHeader("X-Amt-Auth", "12345678");
  int httpCode = http.GET();
  if(httpCode > 0) {
            // HTTP header has been send and Server response header has been handled
            Serial.printf("[HTTP] GET... code: %d\n", httpCode);
            // file found at server
            if(httpCode == HTTP_CODE_OK) {
                Serial.println(payload);
        } else {
            Serial.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
        http.end();
} // setup
By martinayotte
#62610 Your code is instantiating a WiFiClientSecure, but you do nothing with it, so, it is pretty useless.
Also, the HTTPClient isn't in TLS, although you provide 443 port, you need to use the right begin(), the one for TLS :
Code: Select allbool HTTPClient::begin(String host, uint16_t port, String uri, bool https, String httpsFingerprint)
The fingerprint of the server can be copied/pasted from a browser by viewing certificate.
By Ray Alderman
#62616 [quote="martinayotte"]Your code is instantiating a WiFiClientSecure, but you do nothing with it, so, it is pretty useless.
Thanks. I've aded the correct begin with strings of host, uri and fingerprint.
I'm now crashing the ESP8266 and getting a reset with Exception (29):
Exception (29):
epc1=0x4000e1b2 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000008 depc=0x00000000
Progress!
Trying various things but not finding an answer - is there another way to get a SSL GET request with a header?
