By Verlique
#63682 Hi guys, I have a huge problem and i don't know WHY.
I control 2 step motors with my android, but always after a "comand" the Esp give me a WDT error and reset :(
My code:
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <AccelStepper.h> // Responsavel pelas funções dos motores
#include <MultiStepper.h> // Controle de multiplos motores
#define interface 8
half stepper
#define motorPinD1  5     // IN1 ULN2003 driver 1
#define motorPinD2  4     // IN2 ULN2003 driver 1
#define motorPinD3  0     // IN3 ULN2003 driver 1
#define motorPinD4  2     // IN4 ULN2003 driver 1
#define motorPinD5  14     // IN1 ULN2003 driver 2
#define motorPinD6  12     // IN2 ULN2003 driver 2
#define motorPinD7  13    // IN3 LN2003 driver 2
#define motorPinD8  15    // IN4 ULN2003 driver 2
AccelStepper motor1(interface, motorPinD1, motorPinD3, motorPinD2, motorPinD4);
AccelStepper motor2(interface, motorPinD5, motorPinD7, motorPinD6, motorPinD8);
MultiStepper motores;
int motorVel = 1000;
int command = 001;
int cmdPassado;
long posicao[2];
long posicaoA[2];
const char *ssid = "MotoG";
const char *password = "tetando123";
ESP8266WebServer server(80);
/* Just a little test message.  Go to http://192.168.4.1 in a web browser
   connected to this access point to see it.
void handleRoot() {
  //server.send(200, "text/html", "<h1>You are connected</h1>");
  String cmd;
  cmd += "<!DOCTYPE HTML>\r\n";
  cmd += "<html>\r\n";
  //cmd += "<header><title>ESP8266 Webserver</title><h1>\"ESP8266 Web Server Control\"</h1></header>";
  cmd += "<head>";
  cmd += "<meta http-equiv='refresh' content='5'/>";
  cmd += "</head>";
  switch (command) {
    case 010:
      cmd += ("<br/>Device FRONT");
      break;
    case 011:
      cmd += ("<br/>Device BACK");
      break;
    case 110:
      cmd += ("<br/>Device LEFT");
      break;
    case 111:
      cmd += ("<br/>Device RIGHT");
      break;
    default:
      cmd += ("<br/>Device STOP");
      break;
  server.send(200, "text/html", cmd);
void handleNotFound() {
  //digitalWrite(led, 1);
  String message = "File Not Found\n\n";
  message += "URI: ";
  message += server.uri();
  message += "\nMethod: ";
  message += (server.method() == HTTP_GET) ? "GET" : "POST";
  message += "\nArguments: ";
  message += server.args();
  message += "\n";
  for (uint8_t i = 0; i < server.args(); i++) {
    message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
  server.send(404, "text/plain", message);
  //digitalWrite(led, 0);
wdt_disable();
  // Motores
  motor1.setMaxSpeed(1000);
  motor1.setSpeed(motorVel);
  motor2.setMaxSpeed(1000);
  motor2.setSpeed(motorVel);
  motores.addStepper(motor1);
  motores.addStepper(motor2);
  Serial.begin(9600);
  //WiFi.softAP(ssid, password);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println(ssid);
  Serial.print("IP address: ");
  server.on("/", handleRoot);
  server.on("/status001", []() {
    server.send(200, "text/plain", "Device Stop");
    command = 001;
  server.on("/status010", []() {
    server.send(200, "text/plain", "Device Frente");
    command = 010;
  server.on("/status011", []() {
    server.send(200, "text/plain", "Device Tras");
    command = 011;
  server.on("/status110", []() {
    server.send(200, "text/plain", "Device ESQ");
    command = 110;
  server.on("/status111", []() {
    server.send(200, "text/plain", "Device DIR");
    command = 111;
  server.onNotFound(handleNotFound);
  server.begin();
  Serial.println("Servidor Iniciado!");
  server.handleClient();
  switch (command) {
    case 010:
      posicao[0] = 100 +  posicaoA[0];
      posicao[1] = 100 +  posicaoA[1];
      motores.moveTo(posicao);
      motores.runSpeedToPosition(); // Blocks until all are in position
      break;
    case 011:
      posicao[0] = -100;
      posicao[1] = -100;
      break;
    case 110:
      posicao[0] = 100;
      posicao[1] = 100;
      break;
    case 111:
      posicao[0] = 100;
      posicao[1] = 100;
      break;
    case 001:
      motor1.stop();
      motor2.stop();
      break;
    posicaoA[0]+=posicao[0];
    posicaoA[1]+=posicao[1];
By Verlique
#63697
martinayotte wrote:We need to look at the library, there are maybe not ESP aware and using it's own delay() instead of the delay() provide by ESP SDK.
I'm using this link to get this lib:
http://arduino.esp8266.com/package_esp8 ... index.json
(attachment as well)
By martinayotte
#63702 I'm not talking about ESP libraries, but those :
Code: Select all#include <AccelStepper.h> // Responsavel pelas funções dos motores
They probably have some code inside them that is not ESP friendly, such custom delays.
