My webserver works and this works as well http://192.168.1.100/?TEXT=123
However I'm getting this error
Soft WDT reset
ctx: cont
sp: 3fff0530 end: 3fff08a0 offset: 01b0
>>>stack>>>
3fff06e0: 00000001 00000028 3fff0760 402076df
3fff06f0: 00000001 3fff07a0 3fff0760 40206a92
3fff0700: 3ffef5e8 0000000a 3ffef5e8 40206abc
3fff0710: 0000001b 00000022 3fff27c6 402083e0
3fff0720: 0000001d 00000021 3ffef5e8 4020415c
3fff0730: 00000002 3ffeecd0 3ffef5e8 40208411
3fff0740: 00000002 3ffeecd0 3ffef5e8 402073d1
3fff0750: 00000002 3ffeecd0 3ffef5e8 4020211d
3fff0760: 00000000 00000000 00000000 00000000
3fff0770: 00000000 00000000 3fff27a4 0000002f
3fff0780: 00000028 3fff07e0 00000000 40207634
3fff0790: 00000002 00000001 3ffeecd0 40202184
3fff07a0: 00000000 00000000 00000000 4010020c
3fff07b0: 00000002 00000001 3fff247c 40208036
3fff07c0: 00000000 00000000 3fff247c 40204152
3fff07d0: 3fff247c 3ffeed10 3fff247c 4020418e
3fff07e0: 00000000 00000000 00000000 40207840
3fff07f0: 3fff247c 3ffeed10 3ffeecd0 40204221
3fff0800: 3fff25a4 0000000f 00000001 402030f8
3fff0810: 00000000 0000002d 0000002d 00000001
3fff0820: 00000002 0000002d 0000000f 3ffef880
3fff0830: 00000000 00000000 3ffeecd0 3ffef878
3fff0840: 00000001 3ffeecf4 3ffeecd0 4020445b
3fff0850: 3ffe87d8 00000000 000003e8 4020247e
3fff0860: 00000000 3fff257c 40208040 4020802c
3fff0870: 3fffdad0 00000000 3ffef870 4020249c
3fff0880: 3fffdad0 00000000 3ffef870 40207e64
3fff0890: feefeffe feefeffe 3ffef880 40100718
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(1,6)
ets Jan 8 2013,rst cause:4, boot mode:(1,6)
Here is my code.
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include "Adafruit_Thermal.h"
#include "SoftwareSerial.h"
#define TX_PIN 12 // Arduino transmit BLUE WIRE labeled RX on printer
#define RX_PIN 5 // Arduino receive GREEN WIRE labeled TX on printer
SoftwareSerial mySerial(RX_PIN, TX_PIN); // Declare SoftwareSerial obj first
Adafruit_Thermal printer(&mySerial); // Pass addr to printer constructor
// Fill in your WiFi router SSID and password
const char* ssid = "...........";
const char* password = "..........";
MDNSResponder mdns;
ESP8266WebServer server(80);
const char INDEX_HTML[] =
"<!DOCTYPE HTML>"
"<html>"
"<head>"
"<meta name = \"viewport\" content = \"width = device-width, initial-scale = 1.0, maximum-scale = 1.0, user-scalable=0\">"
"<title>ESP8266 Web Form Demo</title>"
"<style>"
"\"body { background-color: #808080; font-family: Arial, Helvetica, Sans-Serif; Color: #000000; }\""
"</style>"
"</head>"
"<body>"
"<h1>Thermal Printer Type and Print</h1>"
"<FORM action=\"/\" method=\"post\">"
"<P>"
"TEXT<br>"
"<INPUT type=\"textarea\" name=\"TEXT\" value=\"test\">On<BR>"
"<INPUT type=\"submit\" value=\"Send\"> <INPUT type=\"reset\">"
"</P>"
"</FORM>"
"</body>"
"</html>";
void handleRoot()
if (server.hasArg("TEXT")) {
handleSubmit();
else {
server.send(200, "text/html", INDEX_HTML);
void returnFail(String msg)
server.sendHeader("Connection", "close");
server.sendHeader("Access-Control-Allow-Origin", "*");
server.send(500, "text/plain", msg + "\r\n");
void handleSubmit()
String TEXTVAL="";
TEXTVAL = server.arg("TEXT");
printer.wake();
printer.setSize('L');
printer.println(TEXTVAL);
Serial.println(TEXTVAL);
delay(3000);
printer.sleep();
void handleNotFound()
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET)?"GET":"POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for (uint8_t i=0; i<server.args(); i++){
message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
server.send(404, "text/plain", message);
void setup(void)
WiFi.begin(ssid, password);
Serial.println("");
printer.begin();
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.println(ssid);
Serial.print("IP address: ");
if (mdns.begin("esp8266WebForm", WiFi.localIP())) {
Serial.println("MDNS responder started");
server.on("/", handleRoot);
server.onNotFound(handleNotFound);
server.begin();
Serial.print("Connect to http://esp8266WebForm.local or http://");
printer.feed(1);
printer.sleep();
void loop(void)
server.handleClient();
}I'm not sure if I need the mdns thing (not quite sure what it is, I assume it's an easier way to access the webpage without knowing the ip.
So I am assuming its the thermal printer as when going over 32 characters is usually an automatic crash.
e.g. http://192.168.1.100/?TEXT=123456789012 ... 4567890123
If I turn comment out the printer aspect, it works =/
any ideas how to fix this? I'm not sure if its a buffer issue or something... I was thinking that cutting the input into small chunks and print in chunks might fix this, but not sure how to do it.
Thanks in advance.
