By whyphi
#66853 Hello,
can somebody tell me, if and how it is possible to get a constant "high" sample rate (>5 ksps) from the EPS8266 internal ADC?
I would like to implement a FFT using the internal ADC under the Arduino IDE.
Thanks
By mrburnette
#66887
whyphi wrote:In the following post, a conversion time of 5us is given?
http://bbs.espressif.com/viewtopic.php?t=2440
... but, that response was for a native SDK application, not for an Arduino 'side loaded' program. The RF section and stack needs to be serviced every 50mS or quicker (normally done when loop() repeats.) So, your A/D and all overhead must complete in 50mS ... a long time, but you need to be aware of the limitations of nonOS which manages the Arduino pseudo-thread.
Ray
