newbie question:
I'm using an ESP8266 with Arduino core, I get from the Serial monitor "0FF022333232FF", do a publish but this is what I receive on the broker "00FF 0002 0233 0302 32FF ".
I have to remove the '0' before the byte I need.
#include <PubSubClient.h>
PubSubClient client(client);
uint8_t charIndex = 0;
uint8_t numChars = 39;
uint32_t lastCharMillis = 0;
uint8_t waitSerial = 25;
bool okPrint;
uint8_t manageIndex;
unsigned char msg[40];
byte bufferCounter = 0;
void setup()
// Serial1.begin(115200);
void loop()
while (Serial.available())
byte incomingByte = Serial.read();
char inChar = (char)incomingByte;
Serial.print("I received: ");
Serial.println(inChar, HEX);
msg[charIndex] = inChar;
charIndex++;
bufferCounter++;
lastCharMillis = millis();
okPrint = true;
if (charIndex >= numChars) charIndex = numChars - 1;
if (millis() - lastCharMillis >= waitSerial && okPrint == true)
msg[charIndex] = '\0';
manageIndex = charIndex;
charIndex = 0;
Serial.println("");
Serial.print("Size of buffer ");
Serial.println(bufferCounter);
Serial.println("");
// Allocate the correct amount of memory for the payload copy
byte* p = (byte*)malloc(bufferCounter);
// Copy the payload to the new buffer
memcpy(p, msg, bufferCounter);
Serial.println("");
Serial.print("Message: ");
for (int u = 0; u < bufferCounter; u++)
Serial.print(p[u],HEX);
Serial.println("");
client.publish("myTopic", p, bufferCounter);
// Free the memory
free(p);
okPrint = false;
bufferCounter = 0;
}Is it possible, or is it due to the library classes/sources ?
Thanks
