I am currently running into an issue where i cannot get my NodeMCU board to interact with nearby networks. I cannot connect to my network via an example sketch in the Arduino IDE by passing in my SSID and password, and when I try an example sketch for scanning for nearby networks, I cannot locate any, despite there being several.
I have two of these boards and both of them exhibit the same behavior, so I'm thinking it's not a hardware issue, as it would be pretty unlikely that both boards have the same problem.
I ensured that my router was broadcasting my wifi network @ 2.4GHz and that the SSID was being broadcast (as opposed to hidden). Other wireless devices can connect without an issue.
I can run other programs fine, such as a blink example sketch. I do have an issue where serial output is garbled, unless I set serial.begin(74880) and the serial monitor to 115200. This issue happens on both boards. I imagine that this issue is not relevant, but since I'm not an expert, I felt it was worth including.
Does anyone have any ideas as to why I'm having trouble?
Thank you.
