I'm having a heck of a time getting connected to my ESP8266's for any length of time and I'm sort of at a loss.
The connectivity is spotty and inconsistent if it works at all, even in the best of conditions. Here are the details:
1. I'm using a few different models to test - a NodeMCU v 0.9, a Lua CH340G v 0.1, and an ESP-12F connected with an ESP socket programmer.
2. I'm using a very simple sketch, basically just invoking SoftAP and then waiting for clients. Here's a link:
https://github.com/esp8266/Arduino/blob ... sPoint.ino
3. I did a fresh install of the Arudino IDE and downloaded the board files (which downloaded the ESP and WiFi libraries fresh as well) yesterday.
And here are the symptoms I'm experiencing:
1. I transfer the sketch to the ESP and the AP appears in my WiFi AP list on my device. I try to connect, and about 2/3 of the time it fails, saying either 'Incorrect Password' or 'Out of range'.
2. About 1/3 of the time it connects, but I end up with an APIPA address (169.254.X.X).
3. Very rarely I'll get a real address (192.168.X.X) but when I try to navigate to the ESP web page at 192.168.4.1) the link crashes and I can't reconnect to the AP.
I've tried connecting to the AP with my phone (iPhone SE) and my laptop (Samsung Chromebook). The behavior is the same regardless of the device I'm using or the ESP I am using.
So, I'm kind of at a loss! If the ESP isn't the problem (because I've tried several), and the code isn't the problem (because it's so simple and demonstrated to be working by others), and my devices aren't the problem (because I've tried several of those), what could the problem be?
Thanks in advance!
