By MartynC
#74892 Hi,
I've started going in circles with this. I am using the Ken Taylor port of the wifiManager library and want to add my own website.
I have the wifiManager library working.
I have the website working when the credentials are hard coded.
Failed at combining the two.
What I would like to achieve:
- Use the wifiManager portal to enter the wifi credentials
- Connect to the local wifi
- serve a small website over the local network.
- Still have the wifiManager portal active but only only when connected directly to the ESP8266 on 192.168.4.1
In the below sketch. The ESP8266 connects to the local network but when I go to the new ip address I get the wifiManager portal. I don't get my website. It appears the captive portal is still active.
The Looping message is not displayed until after I close the portal. After closing the portal the Looping message is displayed but I get no response from the local network. My webpage is not served.
Everything tells me this should be straight forward but I cannot get it to work.
WiFiServer server(80);
//needed for library
#include <ESP8266WebServer.h>
#include <DNSServer.h>
#include <WiFiManager.h>
// Onboard LED I/O pin on NodeMCU board
const int PIN_LED = D4;
String request = "";
unsigned long time_now = 0;
unsigned long time_prev = 0;
void setup()
    pinMode(PIN_LED, OUTPUT);
    Serial.println("\n Starting");
    unsigned long startedAt = millis();
    WiFi.printDiag(Serial); //Remove this line if you do not want to see WiFi password printed
    Serial.println("Opening configuration portal");
    digitalWrite(PIN_LED, LOW); // turn the LED on by making the voltage LOW to tell us we are in configuration mode.
    //Local intialization. Once its business is done, there is no need to keep it around
    WiFiManager wifiManager;
    //it starts an access point
    //and goes into a blocking loop awaiting configuration
    if (!wifiManager.startConfigPortal("ESP8266","password"))
    {    //Delete these two parameters if you do not want a WiFi password on your configuration access point
         Serial.println("Not connected to WiFi but continuing anyway.");
         //if you get here you have connected to the WiFi
         Serial.println("connected...yeey :)");
   digitalWrite(PIN_LED, HIGH); // Turn led off as we are not in configuration mode.
        // For some unknown reason webserver can only be started once per boot up
        // so webserver can not be used again in the sketch.
    Serial.print("After waiting ");
    int connRes = WiFi.waitForConnectResult();
    float waited = (millis()- startedAt);
    Serial.print(waited/1000);
    Serial.print(" secs in setup() connection result is ");
    Serial.println(connRes);
    if (WiFi.status()!=WL_CONNECTED)
        Serial.println("failed to connect, finishing setup anyway");
        Serial.print("local ip: ");
void loop()
    if (client)
        Serial.println("Client is connected");
        request = client.readStringUntil('\r');
        Serial.print(F("request = "));   Serial.println( request );
        client.flush();
        client.print( "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n" );
        client.print( "<!DOCTYPE html><html><head><title>Title</title></head><body><div id='main'><h2>H2 title</h2></div></body></html>" );
        delay(5);
        client.stop();
        Serial.println("Client disonnected");
        time_prev = millis();
    time_now = millis();
    if (time_now - time_prev > 5000)
         Serial.println( "Looping" );
Here's what I get in the serial monitor. The Looping message starts when the portal is closed. Not sure if this is useful.
Code: Select all*WM: Connection result:
*WM: WL_CONNECTED
*WM: Handle root
*WM: Info
*WM: Sent info page
*WM: Handle root
*WM: Server Close
*WM: Sent server close page
connected...yeey :)
After waiting 73.47 secs in setup() connection result is 3
local ip: 192.168.169.2
Looping
Looping
The Esp8266 is connected to the local network but the new webpage is not being served. The connection has been verified.
Would really appreciate some help or a working example.
