SDA --> GPIO04
SCK --> GPIO05
MOSI --> GPIO08
MISO --> GPIO06
Us that possible? How?
IRQ --> NC
GND --> GND
RST --> GPIO0
3.3V --> 3.3V
Explore... Chat... Share...
SPI
SPI library supports the entire Arduino SPI API including transactions, including setting phase (CPHA). Setting the Clock polarity (CPOL) is not supported, yet (SPI_MODE2 and SPI_MODE3 not working).
The usual SPI pins are:
• MOSI = GPIO13
• MISO = GPIO12
• SCLK = GPIO14
There’s an extended mode where you can swap the normal pins to the SPI0 hardware pins. This is enabled by calling
SPI.pins(6, 7, 8, 0) before the call to SPI.begin(). The pins would change to:
• MOSI = SD1
• MISO = SD0
• SCLK = CLK
• HWCS = GPIO0
This mode shares the SPI pins with the controller that reads the program code from flash and is controlled by a hardware arbiter (the flash has always higher priority). For this mode the CS will be controlled by hardware as you can’t handle the CS line with a GPIO, you never actually know when the arbiter is going to grant you access to the bus so you must let it handle CS automatically.
rudy wrote:From page 10 of
https://media.readthedocs.org/pdf/ardui ... sp8266.pdfSPI
• MOSI = GPIO13
• MISO = GPIO12
• SCLK = GPIO14
• MOSI = SD1
• MISO = SD0
• SCLK = CLK
• HWCS = GPIO0
