However, I have noticed two problems:
1) If I do an OTA, the SPIFFS is no longer valid. I get a failure that the file system is not ready. I can format the SPIFFS again and it all works fine, until I do another OTA - then it's gone again.
2) When I use the ESP8266 Sketch Data Upload feature it uploads the data (from the files contained in the DATA folder), but when I try to access the SPIFFS, I get the message that the file system is not ready.
I am using a NodeMCU1.0(ESP-12E Module), 4M (3M SPIFFS),80MHz. My sketch size is 372,276 bytes, which is plenty under the 2x requirement for the ESPhttpUpdate to work within 1M of remaining flash space (when 3M are dedicated to the SPIFFS).
Having the SPIFFS destroyed every time when doing an OTA is unacceptable. Has anyone run into this?
Thanks!
