SPIFFS
/datalog.txtt type='file' name='update'><input type='submit' value='Update'></form>
rather than something expected like this:
SPIFFS
/datalog.txt 1022
I've generally avoided using String types whenever possible and usually use char arrays but in this case I thought I'd try a String since I wasn't sure of the exact length, etc. Do I need to manually add a null terminator and this is just running into the next bit because it is missing? It doesn't have the two spaces between the file name and file size either though. Or is it allocating over top of the other const char array? Is there a better and/or more robust way to handle using Strings?
I'm not near the ESP at the moment to double check but I don't think it was using loads of memory or anything like that. I suppose I could move the htmlUpdate text out of RAM into PROGMEM to free up some as well; the current code was just a small page to make quick test iterations easier.
I reviewed the ESPAsyncWebServer and see I can print directly to the response which I'd believe would solve my issue in a different way but it would be nice to know if there's a better way to use Strings in case I need to in the future.
#include <Arduino.h>
#include <Streaming.h>
#include <FS.h>
#include <Hash.h>
#include <ESPAsyncTCP.h>
#include <ESPAsyncWebServer.h>
const char *htmlUpdate = "<form method='POST' action='/update' enctype='multipart/form-data'><input type='file' name='update'><input type='submit' value='Update'></form>";
AsyncWebServer server(80);
void setup()
SPIFFS.begin();
server.on("/ls", HTTP_GET, [](AsyncWebServerRequest *request) {
String info = "SPIFFS";
Dir dir = SPIFFS.openDir("/");
while (dir.next()) {
info += "\r\n" + dir.fileName();
File f = dir.openFile("r");
info += " " + f.size();
request->send(200, "text/plain", info);
server.on("/update", HTTP_GET, [](AsyncWebServerRequest *request) {
request->send(200, "text/html", htmlUpdate);
server.serveStatic("/", SPIFFS, "/");
server.onNotFound([](AsyncWebServerRequest *request) {
request->send(404, "text/plain", "File not found.");
server.begin();
