Serial.printf ("Docking stations =% d \ n", WiFi.softAPgetStationNum ());To know how many devices are connected to the access point, it will not return to zero after the client is disconnected
But if the PC is connected and then disconnected, it can detect it and print zero
AP:
#include <ESP8266WebServer.h>
#include <ArduinoJson.h>
#define led0 4 //D2
DynamicJsonBuffer jsonBuffer;
const char *ssid = "ssid";
const char *password = "password";
int sensorValue0 = 0;
String sensor_values;
ESP8266WebServer server(80);
WiFiClient client;
void handleSentVar() {
if (server.hasArg("sensor_reading"))
sensor_values = server.arg("sensor_reading");
Serial.print("**********************sensorValue:");
Serial.println(sensor_values);
JsonObject& root = jsonBuffer.parseObject(sensor_values);
sensorValue0 = root["sensor0_reading"].as<int>();
jsonBuffer.clear();
Serial.print("sensorValue0:");
Serial.println(sensorValue0);
toggle_leds();
server.send(200, "text/html", "Data received");
Serial.begin(9600);
WiFi.softAP(ssid, password);
pinMode(led0, OUTPUT);
//toggle_leds(); //turn off all leds as all the sensor values are zero
server.on("/data/", HTTP_GET, handleSentVar); // when the server receives a request with /data/ in the string //then run the handleSentVar function
server.begin();
server.handleClient();
Serial.printf("Stations connected = %d\n", WiFi.softAPgetStationNum());
delay(1000);
void toggle_leds()
if (sensorValue0 == 0){ digitalWrite(led0, LOW);
Serial.println("++++++++++++++++off+++++++++++++");}
if (sensorValue0 == 1){ digitalWrite(led0, HIGH);
Serial.println("------------on-------------");}
}Client:
#define btn0 5 //D1
int sensorValue0 = 0; //sensor value, I'm usingg 0/1 button state
Serial.begin(9600);
delay(10);
pinMode(btn0, INPUT);
// set the ESP8266 to be a WiFi-client
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.print("btn");
Serial.println(digitalRead(btn0));
if(digitalRead(btn0) == LOW) sensorValue0 = 1;
if(digitalRead(btn0) == HIGH) sensorValue0 = 0;
WiFiClient client;
const char * host = "192.168.4.1"; //default IP address
const int httpPort = 80;
return;
// We now create a URI for the request. Something like /data/?sensor_reading=123
String url = "/data/";
url += "?sensor_reading=";
url += "{\"sensor0_reading\":\"sensor0_value\"}";
url.replace("sensor0_value", String(sensorValue0));
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
unsigned long timeout = millis();
while (client.available() == 0) {
if (millis() - timeout > 5000) {
Serial.println(">>> Client Timeout !");
client.stop();
return;
}Where is the problem?
