I'm trying something really simple which is uploading a sketch to one of my ESP12e.
I was able to do it without a problem until a few weeks ago. Now, I receive the following message:
esptool.py v2.8
Serial port COM3
Connecting........_____....._____....._____....._____....._____....._____.....____Traceback (most recent call last):
File "\Arduino15\packages\esp8266\hardware\esp8266\2.6.2/tools/upload.py", line 65, in <module>
esptool.main(cmdline)
File "/Arduino15/packages/esp8266/hardware/esp8266/2.6.2/tools/esptool\esptool.py", line 2890, in main
esp.connect(args.before)
File "/Arduino15/packages/esp8266/hardware/esp8266/2.6.2/tools/esptool\esptool.py", line 483, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
_
the selected serial port _
does not exist or your board is not connectedThe board is connected to a CH340 USB-Serial converter, similar to this https://www.electrodragon.com/product/usb-ttl-serial-ch340-board/
Connection schematics are shown below.
The board sends some basic info back through the serial port, so I assume serial communications work.
I tried with a PL-2303 but it does not work anymore on Win10 (v1909)
I also tried with ESP Flasher from ESPhome.io (https://github.com/esphome/esphome-flasher). Same results...
Any guidance/help will be much appreciated.
