I want to save power on on my ESP8266 Lolin dev board.
The initial programm started WiFi, loaded NTP data and began to run just retrieving every second
localtime(&now);The power draw oscillated between mainly 22mA having some spikes to 60mA.
Now I added
WiFi.mode(WIFI_OFF);Now the power draw is constantly 74mA!
Has someone got an explanation?
That is the opposite of what I would have logically expected!
#define OFFLINE // Remove to keep online
#if defined(ESP8266)
#include <ESP8266WiFi.h> // default from Espressif
//#include <WiFiUdp.h> // default from Espressif
#include <TZ.h> // default from Espressif
#elif defined(ESP32)
#include <WiFi.h> // defaults from Espressif
#include <time.h>
#endif
#define WIFI_SSID "your SSID"
#define WIFI_PASS "Your Password"
#define HOST_NAME "ESP-IoT"
#define NTP_SERVER "de.pool.ntp.org"
// maintain for ESP32
#define TZ 1 // (utc+) TZ in hours
#define DST_MN 60 // use 60mn for summer time in some countries
#define GMT_OFFSET_SEC 3600 * TZ // Do not change here...
#define DAYLIGHT_OFFSET_SEC 60 * DST_MN // Do not change here...
// maintain for ESP8266
#define MYTZ TZ_Europe_Paris
// Variables for Time
static int lastSecond;
tm* timeinfo; //localtime returns a pointer to a tm structstatic int Second;
time_t Epoch;
time_t now;
int Second;
int Minute;
int Hour;
int Day;
int Month;
int Year;
int Weekday;
char DayName[12];
char MonthName[12];
char Time[10];
char Date[12];
static IPAddress ip;
//*** Buffers ***
char charbuff[80]; //Char buffer for many functions
// Constructors
//not needed, yet
void getWiFi()
WiFi.begin(WIFI_SSID, WIFI_PASS);
while ( WiFi.status() != WL_CONNECTED )
delay ( 500 );
Serial.print ( "." );
ip = WiFi.localIP();
sprintf(charbuff, "Connected to IP: %03d.%03d.%03d.%03d", ip[0], ip[1], ip[2], ip[3]);
Serial.println(charbuff);
void getNTP()
configTime(MYTZ, NTP_SERVER);
configTime(GMT_OFFSET_SEC, DAYLIGHT_OFFSET_SEC, NTP_SERVER);
#endif
now = time(nullptr);
Epoch = now;
void getEpoch()
Epoch = now;
void getTimeData()
timeinfo = localtime(&now); // cf: https://www.cplusplus.com/reference/ctime/localtime/
Second = timeinfo->tm_sec;
Minute = timeinfo->tm_min;
Hour = timeinfo->tm_hour;
Weekday = timeinfo->tm_wday + 1 ;
Day = timeinfo->tm_mday;
Month = timeinfo->tm_mon + 1;
Year = timeinfo->tm_year + 1900; //returns years since 1900
strftime (DayName , 12, "%A", timeinfo); //cf: https://www.cplusplus.com/reference/ctime/strftime/
strftime (MonthName, 12, "%B", timeinfo);
strftime (Time,10, "%T", timeinfo);
strftime (Date,12, "%d/%m/%Y", timeinfo);
void disConnect()
// WiFi.disconnect(); //temporarily disconnect WiFi as it's no longer needed
void setup()
getWiFi();
getNTP();
delay(5000);
getEpoch(); // writes the Epoch (Numbers of seconds till 1.1.1970...
getTimeData(); // breaks down the Epoch into discrete values.
Serial.print(F("! Date is ")); Serial.print( Date );
Serial.print(F(" and Time is ")); Serial.println( Time );
#if defined (OFFLINE)
disConnect();
Serial.println (F("Sketch is now running offline with own time"));
#endif
void loop()
// Examples with Strings
yield; Serial.print(F("Thanks God, it is: "));
yield; Serial.print( DayName );
yield; Serial.print(F("! Date is ")); Serial.print( Date );
yield; Serial.print(F(" and Time is ")); Serial.println( Time );
yield;
// Examples with a character buffer (can be used for displays as well)
sprintf(charbuff, "Now is %02d Hour, %02d Minutes and %02d Seconds. The Epoch is: %10lu" , Hour , Minute, Second, Epoch);
yield; Serial.println(charbuff);
sprintf(charbuff, "Date is %s, %02d %s %04d ", DayName , Day , MonthName, Year);
yield; Serial.print(charbuff);
yield; Serial.println();
// Examples with Posix expressions
strftime (charbuff, 80, "Americans say it is %I:%M%p, but Europeans prefer using %T", timeinfo);
delay(1000);
