- Sat Feb 20, 2021 1:43 pm
#90591
Old-school is an analog multiplexer like the
CD4051B. If you have a
perf board shield for the D1 Mini then all you need is the
mux chip and a 0.1uF bypass capacitor and some wire. That solution is handy if you need some extra resistors to scale the voltage with a divider(s) for different levels. Another way is with a
CD4051 breakout board.
The only problem with a mux is that the analog input on the ESP is poor accuracy due to the noise from the CPU and WiFi. It's really only about equivalent to a 7 or 8 bit A/D. If you need better accuracy than that, the ADS1015 4 channel 12-bit A/D converter is an option, or the ADS1115 4-channel 16-bit A/D converter. They're both
here. There's lots and LOTS of examples around the internet with either method (CD4051 mux or ADS1015/ADS1115 4-channel A/D converter). Google it!
