By Perikaruppan
#90967 Dear friends
I am trying to upload selected files from my PC to the SD card over wifi using ESP8266.
I find many programs that use web server, but I am using AsyncWebServer and the programs don't work for Async
I need to upload files to the SD card so that I can select the from the ESP and do my coding based n the text files stored in SD Card
currently I am using a regular USB to store the data onto SD, then plugging the SD into the SD card module attached to the ESP
I need someway in which I can upload my files to the SD card wirelessly
Kindly support
By Perikaruppan
#90978
Pablo2048 wrote:Hi,
you can try to use SPIFFSEditor with SD filesystem instead of default SPIFFS. If it works, then you can use curl to upload filesystem content.
Thanks Pablo. But I am not very familiar with coding in curl.
Any examples which I can look into ?
