Spookily however, I still got the time-out error when attempting the same operations on my desktop PC ... a desktop PC that was previously uploading to two of these MCUs just fine. That is before I uploaded some code to an Arduino UNO and subsequently tried uploading the NodeMCUs again. I'm delighted that the NodeMCUs are all functional, but keen to bottom out how this time-out is caused!
- Physically remove all your USB -> UART convertors (= all your NodeMCU's) from your PC
- Press Windows start button
- Type and open "Device manager"
- Check the "Show hidden devices" option under "View"
- In the tree open up the "Ports (COM & LPT)" node
- Remove all COM-ports; if you have "Real" COM-ports on board your PC (often COM1/COM2), you can leave them as-is
- Plug in your NodeMCU's one by one: they should be detected again and given a COM-port below 10
- From now on, everything should work as expected
